1981 Half Shaft Replacement
Old Mar 22, 2011 | 10:23 PM
1980ZZ4's Avatar
1980ZZ4
Default 1981 Half Shaft Replacement
Interestingly, my wife noticed that one of the rear tires on my 1981 sits into the wheel well a bit further than the one on the opposite side. It really does too. I remember the person I bought the car from noted that he had the half shaft on one side replaced...it happens to be the side that has the problem. I can see that the one in question has been replaced.
What is the likely cause of this? Could the half-shaft be shorter than the stock original? Remedy?
Now I see it and know about it, it will drive me nuts until I fix it.
Thanks in advance.
Brad
Old Mar 23, 2011 | 08:34 AM
1980ZZ4's Avatar
1980ZZ4
bump
Old Mar 23, 2011 | 09:11 AM
Augie 79's Avatar
Augie 79
A shorter half shaft couldn't cause this without bending the trailing arm first. Maybe one side has a wheel spacer? If you haven't had the car very long and never had the wheels off, that's where I'd start. Take the wheel off that sets out the farthest and see if it has a spacer under it.
Old Mar 23, 2011 | 10:27 AM
Mike Ward's Avatar
Mike Ward
Have you measured them? It's very common for C3 bodies to be offset on the frame by half an inch or so. Mines been that way since day one.
Old Mar 23, 2011 | 11:29 AM
wcsinx's Avatar
wcsinx
Sure it can. The halfshafts are the upper link of the rear suspension, so shortening them will give you more negative camber. No change to the trailing arm necessary.
OP, can you measure the camber of the rear wheels? Is it the same on both sides?
Old Mar 23, 2011 | 11:35 AM
Mike Ward's Avatar
Mike Ward
But it will put the arm in severe torsion, extremely hard on the bushing especially if it's the very evil poly wanna cracker type.
Old Mar 23, 2011 | 11:49 AM
DRIVESHAFT's Avatar
DRIVESHAFT
It seems like the length of the 80-82 half shafts is a bit different than the 68-79 cars.
Maybe you have a half shaft on one side from an earlier car.
Old Mar 23, 2011 | 02:10 PM
1980ZZ4's Avatar
1980ZZ4
Admittedly, I was being lazy to ask the question. I think it's time to crawl under the car and take some measurements. Sounds like it might answer some questions here too. I've questioned also whether the replacement half-shaft was for an earlier year. I'll find out and share my findings.
BTW, the car only has the wheel spacers I've put on it to allow me to run my Weld Pro Stars.
Thanks for ALL the replies.
Old Mar 23, 2011 | 02:19 PM
vette427-sbc's Avatar
vette427-sbc
The halfshafts from earlier cars are longer, so if a wrong one was installed, you would have severe positive camber.
early shafts are 13 7/8"
80-82 shafts are 13 1/2"
I would have a look at the strut rods. See if the adjustment bolts are in the same location on both sides.
Old Mar 24, 2011 | 12:47 AM
Gale Banks 80''s Avatar
Gale Banks 80'
If you should end up replaceing a 1/2 Shaft on your 81 keep in mind that Auto's and Manual Trans Cars used diffrent 1/2 Shafts. Auto's used Spicer 1330 and Manuals used 1350 U-Joints.
To 1981 Half Shaft Replacement
