Does anyone know the correct way to tell if you have an Early or Late '77 Vette?? :confused: I've heard of several different ways to tell, but what is the right way?? :cheers: :chevy Thanks in advance!!!!! :D
Post the last 6 digits of your vin code and I can tell you what month the car was built.
Very early 77's had the engine painted orange. From Sept. 76 on the engine was painted blue.
Early 77's had the alarm switch mounted on the front fender, Later ones were part of the door key switch.
Yep and as mentioned above early 77's had no flags on fender just alarm key slot. Brushed horn button, mines #880 August 76
