easy EFP direct to battery instulation
Old Apr 15, 2002 | 11:27 PM
razz1980's Avatar
razz1980
Default easy EFP direct to battery instulation
just finished re-hooking up the electric fuel pump directly to the battery..found a very easy solution..went to radio shack and got fuse line and a lighted on/off switch with three connecters,one for power ,lead, and ground..this looks great and is an easy set -up..ran the fuse wire from battery to the power on the lighted on/off switch..then ran the efp wire to the lead..and ran the ground dirrectly to the neg. ground battery..the switch is sitting next to the fan/ a/c controller and looks great..hit the switch forward and it lights up and the efp turns on...the wires from the battery run thru a hole in the battery box that leads out under the emergency brake cover,too easy,..thanx for all the help on this EFP questions in my earlier posts all.. :cheers: pics availible if anyone wants to do this and set-up and needs help...
