did I harm my steering control valve?
Old Mar 24, 2011 | 10:42 AM
dburgjohn's Avatar
dburgjohn
Default did I harm my steering control valve?
I could not get my puller on it so I used a pickle fork to separate the valve and pitman arm. Only afterwards did I read the many posts saying "don't use a pickle fork". The power steering is working, but it needs more effort than before. Did I break something or is it just the rebuilt steering box I am feeling?
Old Mar 24, 2011 | 11:59 AM
Rally68's Avatar
Rally68
If you removed the arm with a pickle fork you may have damaged the ball stud or internal components. I removed mine with a pickle fork, and put a pretty good gouge in the ball stud shaft...it sanded out, and shouldn't affect the operation of the internal valve components. did you rebuild the valve after removing it from the pitman arm?? I have my valve apart on the bench currently; it seems to me that any damage that would affect the operation of the valve would be apparent upon inspection of the parts.
assuming you removed the hoses, did you get all the air out of the system?
Old Mar 24, 2011 | 09:09 PM
dburgjohn's Avatar
dburgjohn
The valve was not removed other than from the pitman arm. The steering box was what i wanted. I removed box with pitman arm on it.
Old Mar 24, 2011 | 09:47 PM
...Roger...'s Avatar
...Roger...
Usually if you can watch where the ballstud goes into the valve and the ball moves back and forth smoothly (engine off) while turning the wheel you probably didn't damage it.
Old Mar 25, 2011 | 03:05 PM
onebadmofo's Avatar
onebadmofo
I took my car to the tire store......45 min and $70.00 later the job was done and working fine.
Old Mar 25, 2011 | 04:15 PM
trainor's Avatar
trainor
Default To rebuild or not to rebuild?
My steering system is leaking around the control valve and cylinder. I know you guys have had the same problem. So I'm wondering whats the best bang for the buck? New? Rebuilt? Rebuild myself? Running out of money but can't handle the only thing leaking on this 75. Tell me what you think and the best place to purchase. Thanks in advance!!
Old Mar 25, 2011 | 04:17 PM
trainor's Avatar
trainor
Sorry about that, this was supposed to be a new topic. My bad!
To did I harm my steering control valve?
