Fuel Pump Install Question
Old Mar 25, 2011 | 05:15 PM
deltotum's Avatar
deltotum
Default Fuel Pump Install Question
Howdy all,
I recently installed a new fuel pump, but I had to solder on the connector harness from the old pump to make the new one work. I didn't have any rubber seal available that would cover the solder connection--and there didn't seem to be one on the old pump.
I reinstalled it, and it's been working fine. Am I sitting on a time bomb? Does there need to be a rubber wire seal to protect the solder joint from direct contact with the fuel? If so, what is recommended?
Thanks for your help!
Jason
Old Mar 26, 2011 | 12:40 AM
centralcalvette's Avatar
centralcalvette
I assume you covered the solder connection so it won't short to ground. Other then that, you should be good as gold.
Old Mar 26, 2011 | 07:15 PM
Chromie69's Avatar
Chromie69
Don't take this the wrong way but I would not have soldered that joint..a good crimp connection is all that is needed..especially in a high amp fuel pump..if the pump fails it can increase the amp draw to max out the fuse but not burn it out..what can happen is the solder can melt and then create a spark inside the tank as it connects and disconnects in the tank..I rarely solder anything..unless you used a high temp solder..or a crimp connection and solder I wouldn't leave it that way..new cars don't use solder on anything but inside all the computers where voltage drop actually matters..as far as needing it covered all that is needed is to make sure it doesn't touch ground..as stated above.
Old Mar 28, 2011 | 12:29 AM
deltotum's Avatar
deltotum
Thanks for the advice. I'll check it again--though I may have to drive it to empty before I take it out again.
To Fuel Pump Install Question
