Wanted: True engine experts opinion on this build.
http://www.sehrpower.com/pdf/400hp_383_Dyno_Package.pdf
http://www.katechengines.com/street_...e_packages.php
KAT-A4730 Street Attack LS7 : 7.0L, 427in3
Top-tier LS7 performance engineered for street applications . Crate engine features Katech 11:1 compression forged pistons, solid small-end rod bushings, Torquer LS7 camshaft, and valvetrain enhancements. The perfect choice for high power, daily driven vehicles.
Application: 2006-2009 Corvette Z06, Hot rods, off-road vehicles, show cars
Displacement: 427ci, 7.0L
Bore: 4.125
Stroke: 4.000
Compression ratio: 11:1
Fuel: 93 octane
Horsepower: 600
Torque: 570
Block: LS7
Heads: LS7
Crank: LS7 forged steel or optional Callies forged steel
Connecting rods: LS7 powdered-medal Titanium, rebushed
Pistons: Katech forged aluminum with optional DLC coated pins
Camshaft: Katech Torquer LS7
Oiling system: LS7 dry sump or optional ARE Stage 1, 2, or 3
Throttle body: 90mm electronic or cable
Intake manifold: LS7
Starting at $9,400 plus core
KAT-A4735 Track Attack LS7: 7.0L, 427in3
The ultimate normally-aspirated LS7 crate engine for off-road / track use applications. Drawing from over two decades of experience with championship winning pushrod V8s, this package is race ready. Features Katech 12:1 or 14:1 compression forged pistons, solid small-end rod bushings, high output camshaft and valvetrain enhancements. Available with electronic or mechanical throttle.
Application: 1997-2009 Corvette road race and drag race cars, Hot rods, off-road vehicles, show cars
Bore: 4.125
Stroke: 4.000
Compression ratio: 11:1, 12:1, 13:1 or 14:1
Fuel: 93 octane (11:1), 100 octane (12:1), 105 octane 13:1+
Horsepower: 620-685
Torque: 550-565
Block: LS7 with ARP studs
Heads: LS7 with ARP studs
Crank: Callies forged steel
Connecting rods: LS7 powdered-medal Titanium, rebushed (11:1 or 12:1), Callies H beam steel or optional Carrillo A-beam (13:1 or 14:1)
Pistons: Katech forged aluminum with DLC coated pins
Camshaft: World Challenge or GM Stage 3
Oiling system: Dailey 4 stage dry sump system
Intake manifolld: LS7
I think you could do much better price wise if you assemble the parts and put it together your self. You could do a similar engine in your garage for about $3500. or less. But in the world of you want someone else to do it all and all you do is sign the check, what your looking at is about what anyone would charge, Time is money!!! But you will always get differencing opinions on anything one could ask. If after talking with this company you feel good go with them!!!
Personally, I would build something around the new large port Vortec heads Chevy has. They have both perimeter and center bolt valve cover holes so you can make them look old school.
http://forums.corvetteforum.com/c1-a...17-tt-iis.html
this
And 35 years of building cars and engines for my hobby.
before saying, build it yourself... ask the question, CAN you build it yourself? DO you have the tools? DO you have the time? Do you have the knowledge to pick the correct parts?
There are SOME very smart guys here that do know how to build (Way smarter than I).... and then there are a ton of ones that THINK they can do a build....
Maybe take the time (a month or so) to determine what parts you may want to use... find someone reputable to assemble the short block for you. putting together the long block (top end part)is much easier...
and remember.... "THERE IS NO REPLACEMENT FOR DISPLACEMENT"..... CUBES.... as many as you can get.....I wish i would have put in a SB 427 rather than the 383... and you can stroke it more than just a 383...I THINK you can go as far as a 396, or somewhere close, with your 350 block....
I have ~$3K in my valve train alone!!!
~500 retro roller, ~350 RR... ~ push rods~$100.....~150 Springs ~$1000 porting, polishing and portmatching...and ~$1000 for the heads.... Now through in the forged pistons, Scant crank, Demon carb, fluid HB, MSD ignition system, headers, bigger better oil pans, and pumps, intake, pretty stuff that makes it look fast..... and more.... easy to hit $7-10K..... doing it yourself...
It only take 1 thing to go fast....... MONEY.
Ive got a set of Edelbrocks from the 60's hanging on the garage wall because they wouldnt fit with the new engine and too valuable to just scrap.
Price is way out of line for a 400 HP cast internals engine.If your Budget is there look at this, Fully forged 434 assembled short block.
http://www.musclecars.net/parts/Bran...165991576.html
You can buy a set of AFR 210 eliminator heads, factory style hydraulic roller cam and your set for under $7000. some assembly required. If these were available when I built mine this is the way I would have gone.
PS almost any head can use factory style valve covers except the vortecs and some of the aftermarket vortecs can even use the stock style valve covers. Spray paint the block and heads orange and your good to go. You can get over 500 hp out of this combo with a near stock look, idle and manners and never have to pull over 5500 rpm.
