Exhaust headers with angled plug heads
Old Mar 29, 2011 | 09:18 AM
Dream Bikes's Avatar
Dream Bikes
Default Exhaust headers with angled plug heads
On my 383 I've got Edelbrock angled plug heads, could you help me to find compatible exhaust headers (I konw there are problems...) ??
Standard exhaust (no sidepipes) 2.5"
The car is a 69 SB with steeroids and hydraboost.
Thanks!!!!
Old Mar 29, 2011 | 02:34 PM
c3corvette77's Avatar
c3corvette77
A lot of guys here are running the Hooker Super Comps with angle plug heads. Hooker says they won't fit angle plugs but evidently they do.
Old Mar 29, 2011 | 03:06 PM
brando1118's Avatar
brando1118
Yep. Dart Pro 1 angle plug heads and Hooker Super Comps full length. Standard plug size. No fit issues at all.
Old Mar 29, 2011 | 04:01 PM
gkull's Avatar
gkull
I've had both 1 5/8th Heeadman headers and 1 3/4 Hooker super comp on my vette with angle plug heads.
Brodix and Dart were fine without spark plug clearance problems.
AFR on the other hand just SUCK This fix with AFR heads is to cut the pipes off the flange and add about a one inch pipe to each of the four primaries and reweld them up on the passenger side only.
Old Mar 29, 2011 | 06:18 PM
rhpkdp's Avatar
rhpkdp
6th Gear
They do, but they're tight. Use "shorty" plugs if you can find them.
Old Mar 29, 2011 | 07:04 PM
WTFizzit's Avatar
WTFizzit
Stan's tri-y's, better for low / mid rpm torque, not so much for high rpm / race
Go to C3 Corvette Parts & Mechanicals Gallery and search for "C3 SB Stan's headers" to see what one looks like hanging on Trick Flow angle plug head
Compact, well made, pricey
Old Mar 29, 2011 | 08:31 PM
C3 Stroker's Avatar
C3 Stroker
Thanks!!!!
Not sure about Edelbrock angled heads; they use a different angle than the standard L-98 angle that AFR (fits OK) and other manufacturers use. I know older E-brock angles do not fit with Hookers, and Hooker stated this info on their website. Newer Edelbrocks may have changed to the standard angle. I'd call or check with someone who runs this combo.
Old Mar 29, 2011 | 08:38 PM
Dream Bikes
Thanks guys, but the real problem is about Edelbrock heads which has a strange angle different from other angle heads, so I'm looking for someone has installed Edelbrock angle heads to know what kind of exhaust header I can use..
Old Mar 30, 2011 | 09:38 PM
Dream Bikes
If can help the heads are Edelbrock Performer RPM #60999
To Exhaust headers with angled plug heads
