Restoring a dented rubber rear bumper
Old Apr 16, 2002 | 03:04 PM
Marc01's Avatar
Marc01
St. Jude Contributor
Default Restoring a dented rubber rear bumper
The lower corner of my rubber rear bumper was hit before I got it. Its buckled a little bit, sort of folded over on the area next to the exaust pipe. The top has seperated about 1/2 inch from the body from the stress.
Has anyone ever tried pushing the rubber back into place? Someone mentioned that heating it up might work. If that's the way to go, how do you think it should be heated? Foil and a blowtorch?
I'm not worried about paint ... I'm painting the whole car later anyway.
I'll post a pic of it tonight.
If it can't be done, how much do you think a used bumper is worth?
Thanks.
Old Apr 16, 2002 | 04:03 PM
Marc01's Avatar
Marc01
Default Re: Restoring a dented rubber rear bumper (Marc78)
Here's the picture. The dent is on the right.
I think if I get new mounting hardware, I might be able to secure the top again.
Whaddya think? Is it possible, or am I just kidding myself? :rolleyes:
Old Apr 16, 2002 | 04:58 PM
Smokehouse69's Avatar
Smokehouse69
Cruise-In VI Veteran
Cruise-In VII Veteran
Marc, I'm certainly not an expert on rubber bumper cars, but it looks like that there is probably some support structure under that bumper cover, that is dented.
Hopefully someone who really knows something can tell you what's under there. If you have a copy of the AIM for your car, it might show you.
Old Apr 16, 2002 | 09:47 PM
FNG's Avatar
FNG
Hi Marc. we fix rubber covers all the time at our shop. i think you can buy the retainers( the strips that hold it on). Anyway , get some of those , pull the bumper and heat it up with a heat gun. kinda like a hair dryer on steroids, and heat it and push it out at the same time. most of it should come out. the problem is going to be with getting the high spots down. like where it's pooched out at the top. if you can get that part of it down far enough you can grind it a little and fill the low spots with some "duramix 40-40" good stuff and properly applied will last forever. I glued a lincoln town car front cover with it once and about 2 months later the car came back with the front end torn off of it. the bumper repair still held tight. wear some gloves and use a small piece of wood to push it back in to shape, cuz if it's cool enough to touch, it aint hot enuff!!.once you get it pretty close cool it off with an air blower and it should stay put. any questions, shoot me an e-mail. glad to help if i can. regards, Judd
To Restoring a dented rubber rear bumper
