Is this a suitable cam
Engine: 350 +.060
Piston head type/material: Flat with slot, forged (TRW#L2417F L-82 piston)
Deck: stock height
Compression ratio: (10.0:1+)
Edelbrock 2101 intake idle-5500rpm (also have Stealth Manifold: idle-6800rpm)
Edelbrock RPM heads (64cc)
Edelbrock 600cfm carb (thinking of ditching for my new in box Mighty Demon 750)
Do not recall cam specs of current cam, it was a Lunati cam.
Stock convertor.
After all of that: Here are the specs of the two cams im looking at:
RPM range: 1,800-5200rpm
Adv Dur: 274/274, Dur @.050: 218/218
Valve Lift: 450/450
LSA: 106
Description: Largest cam for stock convertor 9:1 and higher cr, lopey idle, excellent midrange power.
Cam#2
RPM Range: 1,500-5,000rpm
Adv Dur: 272/272, Dur@.050 lift: 216/216
Valve Lift: 454/454
LSA: 110
Description: Lopey-Rough idle, excellent midrange power 9:1 and higher cr, stock convertor.
Phew, comments please.
Another good cam you might want to look at is the Engle 21043-H with 222 degrees on a 110 LSA.
Yes, the '151' was used in the L79 327/350 HP cars.
LSA, Duration @ .050, Lift and ground in advance and advancing or retarding cam from straight up will affect the mannerisms of the cam but to get the right DCR this is the closing point you need and the way to find that closing point.
Edit: The comp 270H has an intake closing point of 61. It will work but you can go a little lower on the intake closing point to bump DCR and lower your operating range. I would look at a split duration cam especially if you don't have 2 1/2" free flowing exhaust. The RPM heads are a little weak on the exhaust side.
Cam # 2 has an intake opening of 62.
The "151 cam has Advertised duration of 290/290, Duration @ .050 is 222/222, LSA is 114. Intake closing point is 79. These were used in an iron head 327 and like lots of RPM. The wider LSA opens up the operating RPM range as you will see when you start comparing cams. It will reduce peak power slightly at high RPM but it will pull better at the bottom and midrange where you use it most. This is why the factory used 114 LSA on most of the old school grinds.
Going a little bigger than 57 is not all bad. That is an absolute minimum I would go. A later intake closing is safer from detonation. A little more lift and duration @ 50 will help with cylinder filling, (valve is open longer and for more time) somewhat compensate for lower dcr it also increases power. You are making use of the capacity of your heads. This also increases your ramp rate. Nothing is free.
I like this cam for your build. Intake closes @ 61 ABDC This is a very commonly used cam for your build level.
http://www.compcams.com/Company/CC/c...x?csid=86&sb=2
This one gives you more lift and duration @ .050. Gets you closer to your 230 dur .500 lift while still having a 270 advertised duration with an intake closing point of 63 ABDC. Look at the operating range. A vette has a better torque convertor stock than your other chevy's, I believe 1800-2000 RPM.
http://www.compcams.com/Company/CC/c...x?csid=97&sb=2
PS: I always recommend a roller cam but it sounds like it is not in the budget. Use proper break in procedures, Moly break in lube, ZDDP additive during break in, good geometry and High ZDDP oil. Be careful.
http://www.cranecams.com/product/car...detail&p=23979
up around 20 mpg with a 3.55 rear end. compression did get me with flat tops and iron 64 cc heads and I went to its bigger brother the Crane 278.
I would run the 600 carb and the stealth manifold. I used a EDL 750 VS carb for more than 10 years on my 355 ci mouse motors with single planes and a 1/2 inch wood thermal spacer. The stealth is a better choice and a 1/2 inch thermal spacer
when you are talking about lobes with sub .500 lift with 1.5 rockers They need any help that they can get with 1.6. lift gives more flow without the adverse side effects of additional duration. That is why I went to high .600 to over .700 lift exhausts
When a motor makes more TQ you don't have to go to increased stall T converers. A 358 with 10 ish compression makes way more power than the original L-82 sold in the late 70's vettes.
Your aluminum heads will help on the pre-ignition, but modern cams and your better heads fill the cylinders better which leads to the need for more duration to keep dynamic pressure lower. If your pistons are flat tops with like -8 cc for valve reliefs I would lean more toward the crane power max 278
