79 AC Wiring
Old Mar 29, 2011 | 08:35 PM
76yellow's Avatar
76yellow
Default 79 AC Wiring
I'm trying to put this 79 back together that Bubba must have spent alot of time on. I'm just about there but have one wire I can't find a place for. Its green & about 18" long with a single female connectoron it & comes from the harness that goes to the AC compressor. I figured out the black & green to the compressor but can't find a place for the long green wire. I've found lots of wiring diagrams but none of them show the AC wiring. So if anyone can help or find a diagram I would greatly appreciate it....Thanks
Old Mar 29, 2011 | 09:37 PM
Peterbuilt's Avatar
Peterbuilt
From a 74 not sure if this will help.
Old Mar 29, 2011 | 09:48 PM
KapsSA's Avatar
KapsSA
Active Streak: 90 Days
That green wire goes across the front of the intake manifold and plugs into the AC idle solenoid on the driver/front side of the carburator.
If you have a manual trans it wasn't used, probably just tucked back into the harness.
Old Mar 29, 2011 | 11:13 PM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
Old Mar 30, 2011 | 09:33 AM
76yellow's Avatar
76yellow
Thanks a bunch guys. The car was an automatic but now a 4 spd. I do still have the AC Sol. on the carb. Should I plug it in or just remove the Sol & tuck it away ?
To 79 AC Wiring
