no electrical power
Old Apr 2, 2011 | 09:56 PM
mvette76's Avatar
mvette76
Default no electrical power
i started my 75 today let it run for about twenty minutes or so i shut it off to see why my electric fan wasn't coming on and tried to restart and nothing. i jacked the car up removed the ground bolt cleaned and re installed still nothing no lights radio nothing but if i jump the starter it turns over so any suggestions?????
Old Apr 3, 2011 | 06:53 PM
doctorgene's Avatar
doctorgene
Have you checked the ground wire from the right motor mount to the frame?? It has also been suggested that you use another ground wire from the frame to the transmission tail housing, which I plan to do when I get around that area again. also the original batt. ground cable will ca rode, inside itself, & cause that problem. Have a great day. Gene
Old Apr 3, 2011 | 08:51 PM
mvette76's Avatar
mvette76
got it figured out! Bubba strikes again with a bad splice!
To no electrical power
