Max timing?
Old Apr 3, 2011 | 05:42 PM
corvettedave383's Avatar
corvettedave383
Default Max timing?
Ive got a sbc 383, aluminium heads, big cam, its fast xfi fuel injected, comp ratio 9.2
whats the approx max wot timing? 36 degrees?
thoughts?
cheers, dave
Old Apr 3, 2011 | 06:23 PM
Gordonm's Avatar
Gordonm
32 to 36 degrees depending on your heads. Some of the newer fast burn chambers do not need the 36 degrees and actually lose some power with that much advance.
Old Apr 3, 2011 | 07:06 PM
corvettedave383
I have Dart pro 1 platinum alum 215cc heads, peak hp is at 6700 rpm
do these heads have fast burn chambers??
cheers
dave
Old Apr 3, 2011 | 07:39 PM
gkull's Avatar
gkull
Yes, run your motor up to 3500 rpm and check the timing. 32-34 degrees is all you need (with vacuum advance disconnected).
I used a Crane cams adjustable vac advance and limited vacuum advance to 6-8 additional degrees.
Old Apr 4, 2011 | 01:13 PM
Birdman's Avatar
Birdman
Sorry to beat a dead horse here..
but would I do the same thing for my 327 w/stock heads, block and aftermarket HEI, Intake, Carb, headers?
Old Apr 4, 2011 | 04:32 PM
LB66383's Avatar
LB66383
Birdman........Yes, set the timing at 34 to 36 degrees maximum at 3,000 to 3,200 rpm. That's with the vacuum advance disconnected. Then connect the vacuum advance to manifold vacuum. I'm guessing that, with the HEI, you'll have about 14-16 degrees of initial advance. That isn't all that important, the max advance is the important number.
Old Apr 4, 2011 | 04:43 PM
gkull's Avatar
gkull
The 3500 or even 3800 is to ensure that you have full mechanical advance. Actually yester year iron heads require about 36 -38 degrees max advance.
then you go out and road test to ensure no detonation under WOT (where the vacuum advance is zero) Then also cruising on a level freeway where vacuum is max and so it vac advance.
You have to hook you vacuum advance to the Ported carb port so it ads very little advance with closed throttle blades
Old Apr 4, 2011 | 06:12 PM
corvettedave383
Thanks for info, the fast xfi controls timing, so I just need to check the check the spark table for levels and changing the timing at different points on the map
cheers
dave
To Max timing?
