Hesitation kills.....performance issue need help
Old Apr 4, 2011 | 09:14 PM
UCVette's Avatar
UCVette
Default Hesitation kills.....performance issue need help
I have a 1978 vette with an L82. Motor is pretty much stock except for new Holley fuel pump & Accel distributor. New AC Delco plugs and new Accel plug wires. Hedman Headers and no cats. When I am at a stand still and punch it, the car hesitates for a second and then takes off kinda slow. Even when I am going around 30 mph and floor it, the car just sits there.
I don't expect to burn off the tires but I feel it should have more get up and go.
Any suggestions?
Old Apr 4, 2011 | 09:44 PM
Avette4me's Avatar
Avette4me
Cruise-In VIII Veteran
Without seeing the car, my interweb guess is timing. Sounds like an advance problem.
Old Apr 5, 2011 | 08:55 AM
78IndyPace's Avatar
78IndyPace
The carb gurus will probably chime in, but the first thought I had while reading your post was: carb accelerator pump.
Check this out:
http://forums.corvetteforum.com/c3-t...t-quality.html
Easy to check. With the air cleaner off, move the throttle linkage toward the rear while looking down the primary carb bores. You should see gasoline spurt from 2 small holes as you increase the throttle opening. Can be done with motor on or off. No spurts = bad accelerator pump = replace with known good pump from Cliff's High Performance. Link:
http://www.cliffshighperformance.com/acc-pump.html
Last edited by 78IndyPace; Apr 5, 2011 at 12:59 PM. Reason: Added accelerator pump test suggestion
Old Apr 5, 2011 | 10:05 AM
MelWff's Avatar
MelWff
assuming it's an automatic, its sounds like the kick down mechanism/solenoid is not working, i believe there is a cable that requires adjusting
To Hesitation kills.....performance issue need help
