Power brake booster clearance
Old Apr 6, 2011 | 08:25 AM
bashcraft's Avatar
bashcraft
Default Power brake booster clearance
I'm thinking of converting to power brakes with this kit.
http://www.jegs.com/i/JEGS+Performan...31052/10002/-1
My question is, will this booster clear big block tall valve covers?
Old Apr 6, 2011 | 10:02 AM
noonie's Avatar
noonie
Stock boosters are 8 3/4" dia if that helps.
7" dual diaphragm boosters that can be adapted are also available.
Old Apr 6, 2011 | 10:42 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Call customer services at JEGS and ask.
Old Apr 6, 2011 | 11:27 AM
bashcraft's Avatar
bashcraft
All they can tell me is that it'll fit with the stock hieght covers.
Old Apr 6, 2011 | 11:28 AM
bashcraft's Avatar
bashcraft
How much adapting is involved with the 7" booster?
Old Apr 6, 2011 | 12:59 PM
pauldana's Avatar
pauldana
Just go a hydro boost.... like WAY better.... this is an upgrade you will NEVER regret. it turns the brakes into AMAZING.
Old Apr 6, 2011 | 01:07 PM
bashcraft's Avatar
bashcraft
Don't have, and don't want power steering.
Old Apr 6, 2011 | 01:13 PM
pauldana's Avatar
pauldana
Whos talking power steering? this is for brakes.
Old Apr 6, 2011 | 01:15 PM
bashcraft's Avatar
bashcraft
I'm under the impression that it works off of the PS pump.
Old Apr 6, 2011 | 01:20 PM
pauldana's Avatar
pauldana
Yes it does, but you dont have to have PS to have a ps pump. do a search on them(hydor boost)... you will find that anyone that has done this mod can't say enough good about it. Cost me $300 and it was the best $300 I have ever spent on her....
Its hard to explain what a difference it is, but it is amazing... best brakes I have EVER EVER had.... actually like them better (the feel) than my C5 brakes
Old Apr 6, 2011 | 01:58 PM
bashcraft's Avatar
bashcraft
That would probably my best choice if I already had a PS pump. Just a quick search reveals that it'll cost me at least $450-$500 for all the brackets, braces, pulleys and a pump. $800 is more than I'm willing to spend on this little venture.
Old Apr 6, 2011 | 10:58 PM
mysixtynine's Avatar
mysixtynine
Ive heard of most guys having issues with tall valve covers by the booster and the wiper door actuator (especially the older style actuator). I have tall covers on my motor and am going to try this 7" booster
http://www.jegs.com/i/Stainless+Stee...28152/10002/-1
Old Apr 7, 2011 | 07:12 AM
noonie's Avatar
noonie
I checked into this a while ago to try and achieve a firmer pedal than the soft stock setup since the diaphragm size and amount of vacuum is one factor that determines the pedal pressure. I just decided to go another route.
The master mount is pretty common and the 4 stud firewall mount is no more work than converting a manual car to boosted. A universal type booster also has an adjustable pedal rod.
We have a couple of booster rebuilders fairly local, so they were of some help.
Here is an example of the firewall mount needed, don't know if the master mount will fit either oem master style.
Basically, if everything mounts properly, any booster works with any master or pedal linkage.
http://www.carolinaclassictrucks.com/PB7537C.html
Old Apr 7, 2011 | 08:25 AM
bashcraft's Avatar
bashcraft
Thanks, it looks like this is my best option.
To Power brake booster clearance
