I am putting my new engine together- trying to determine the correct push rod length. I have a hydraulic roller and bought Comp Magnum 1.6 roller tip rocker arms. (Not the full roller just the tip) The problem is no matter how high or low the rocker arm sits on the stud the roller is out close to the outside edge of the valve stem. Is this the way the 1.6 rocker ends up, and is it ok there? I have never used 1.6's and was wondering if they are supposed to be closer to the center of the valve stem.
You can contact Comp cams and tell them of your setuup. I'm sure others will reply to assist with this issue as well. I'm sure you are already aware of the importance of proper valve train geometry. Yes the roller tip must be centered over the valve stem. Sounds as if these rockers are not self aligning (as with most are not I believe) Do you have aluminum heads? What I can tell you if you may need hardened pushrods as you may have to adjust the guideplates on the heads. I'm watching this b/c I'm waiting for my new cam to arrive and i also wonder if I will have to have longer pushrods. I have crane cams 1.6 roller tip rockers on now. I'm keeping an eye on this thread as I'm in the same boat as you.
There's way too many variables here for a one size fits all pushrod length. But, shorter pushrods will bring the contact patch towards the intake ports. To get the geometry correct, you will need two lightweight check springs, I bought mine from the hardware store and an adjustable pushrod. Install the lightweight springs on #1 cylinder.
Make sure you use the lightweight springs. If you are using hydraulic lifters, they will collapse all the way before the valves open; resulting in incorrect measurements.
I understand how it is supposed to be done- I have an adjustable push rod checker- the problem is no matter how long or short I make the pushrod the rocker arm contact point is toward the exhaust side of the head. The pattern is not way outside, about middle of the valve stem and out from there.
Sometimes you cant get the roller to hit the valve dead center.
It is way more important that you limit the amount of rocker sweep across the top of the valve.
If the pattern is a bit outside but really narrow I would call it good and run it.
One problem with hydraulic roller lifters is that when you spin the motor over to check your pattern, the lifters are likely to collapse. If that happens you cant properly check the pattern.
And since hydraulic roller lifters are taller than solid rollers you cant substitute a solid lifter to do it either, though low travel hydraulic roller lifters do exist.
If your lifters are collapsing, lightweight "checking" valve springs can come in handy.
It looks like Ben Lurkin already covered this last part above. I guess I need to pay better attention.
