C3 front mono spring upgrade
Old Apr 8, 2011 | 09:51 PM
rworley6641's Avatar
rworley6641
Default C3 front mono spring upgrade
Has anyone else thought about doing front mono DIY upgrade?
Old Apr 9, 2011 | 12:27 AM
MN80Vette's Avatar
MN80Vette
I put in the front monospring conversion (not the complete kit) and really like it. The adjustable ride height and spring rate are great. I have the stock lower A-arms but tubular upper A-arms. In hindsight, I should have saved up some more $$ and boght the complete kit with upper and lower tubular A-arms. I had to widen a hole in the lower A-arm so the bolt wouldn't rug. Still one of the better upgrades I made to my '80.
Old Apr 9, 2011 | 06:15 AM
Gordonm's Avatar
Gordonm
I have the full kit front mono spring in mine. I like the adjustability of both spring rate and ride height. I really like it. Pricey but what is not with a Vette.
Old Apr 9, 2011 | 06:54 AM
gkull's Avatar
gkull
I don't know kit you are looking at the VB&P $700 beginers or the $960 with lower a-arm. Each of these kits still need a shock, so add that item on top.
I'd be asking what are the min and max spring rate of the mono systems. I don't know what they are?????
There are alternatives. Have you looked at semi coil over and full coil over fronts?
Old May 10, 2011 | 07:36 PM
rworley6641
ON SALE $519.00 check it out.
Old May 10, 2011 | 10:31 PM
3JsVette's Avatar
3JsVette
While it doesn't say it anywhere you can pick the spring rate you're looking for. If I'm not mistaken (and I very well could be) I believe there is about a 150lbs of adjustment from the softest to the stiffest setting. The springs are also "marked" so that if you already have the mono spring conversion you can call VB&P and tell them what the markings are and they can tell you what spring rate you have. That was told to me by one of the VB&P people at Carlisle when I asked the same question you did.
Old May 11, 2011 | 10:52 AM
rworley6641
Default mono spring
I just installed the front mono spring kit on my frame up restoration. Very easy to do. I went with this upgrade mostly because of the adjustable ride heighth and adjustable spring rate. Also went with the Borgeson steering box and will look at the electric headlamp upgrade as well as 5 speed trans and LS motor. Any thoughts on this will be appreciated.
To C3 front mono spring upgrade
