Need Help My Car Won't Start
Old Apr 9, 2011 | 08:55 AM
78vettetroubles's Avatar
78vettetroubles
Default Need Help My Car Won't Start
I just got the car and it started fine then yesterday when I went to start it nothing happened. There was a little buzz in the engine compartment up front near the passengers side. I replaced the starter and that didn't do anything to help the problem. I checked the alternator and the battery and both are fine. Also there is current to the starter. When I jump started it with a screwdriver it turned over a little bit but it didn't actually start it up. Any ideas on what I could do to fix this problem. I'm running out of ideas. Please help.
Also the red "GEN" light in the center console comes on intermittenly but the alternator tests out fine.
Old Apr 9, 2011 | 09:04 AM
C3 4ME's Avatar
C3 4ME
IF it turned over by a little by jumping with a screwdriver, it leads me to believe there is stll something wrong with the starter.
Old Apr 9, 2011 | 09:09 AM
78vettetroubles
Default how could it?
How Could that be I replaced the starter with a new one.
Old Apr 9, 2011 | 10:02 AM
Phil Zell's Avatar
Phil Zell
Check your ground wires
Old Apr 9, 2011 | 12:27 PM
Kevin_73's Avatar
Kevin_73
Cruise-In X Veteran
St. Jude Donor '09-'11
Check the engine ground cable next to the passenger side engine mount, and check the negative battery cable too.
To Need Help My Car Won't Start
