thermostat
Old Apr 9, 2011 | 05:22 PM
briz's Avatar
briz
Default thermostat
Hello guys..
someone know what kind of thermostat needs for 327 engine in corvette 1968?
160° - 180° -195°???
I have a problem with temperature gauge.
it doesn't work.
I changed it with new one,but the temp is already under 100°.
I changed the temp bulb too.
nothing
now I think the prob is the thermostat.
thank you
briz
Old Apr 9, 2011 | 05:41 PM
larrywalk's Avatar
larrywalk
Veteran: Marine Corps
180 degree thermostat is best - a 160 is too cold and will cause more wear over the long term. A 195 will also work well in winter or cold climes.
Old Apr 9, 2011 | 06:33 PM
doctorgene's Avatar
doctorgene
Yes Sir; Larrywalk is right on the money. Just remember, If it isn't boiling over, you don't have a heat problem. Have a safe summer. Gene
Old Apr 9, 2011 | 07:42 PM
briz's Avatar
briz
thank you gays...
thank you thank you thank you
briz
Old Apr 9, 2011 | 08:14 PM
trainor's Avatar
trainor
Originally Posted by briz
thank you gays...
briz
I'm hoping he meant GUYS!!!
Old Apr 9, 2011 | 08:32 PM
briz's Avatar
briz
ops...
yes trainor i meant guys...
please forgive me for the mistake
bye
briz
Old Apr 9, 2011 | 11:10 PM
73, Dark Blue 454's Avatar
73, Dark Blue 454
Agree,..180 degree thermostat is needed.
Also, if your temp gauge is under-reporting, you likely have an incorrect sender. Today, there's no sender that reports accurately, even the ones that claim to, such as Lectric Limited and the sender sold by Zip.
BWD makes a sender that's close (reads about 85% of actual temp).
Old Apr 11, 2011 | 08:17 AM
briz's Avatar
briz
thank you guys..
Dark Blue, so you think there are different senders and not all are good for my type of engine.
i bought sender for my 68 vette from ecklers...
thank you.
briz
Old Apr 11, 2011 | 10:49 AM
larrywalk's Avatar
larrywalk
I tested a couple of senders and here's the graph - the Wells TU-5 seemed to work best. In any event, it's best to check the outlet temperature with a handheld IR gun.
To thermostat
