Removing A/C - questions
Old Apr 9, 2011 | 08:39 PM
UCVette's Avatar
UCVette
Default Removing A/C - questions
I decided to remove my AC compressor (don't use, want less weight more power). I removed the actual compressor and the brackets. I will get around to everything else like hoses, condenser, etc later however will it hurt anything to leave it like this for now?
Old Apr 9, 2011 | 09:01 PM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
It won't hurt anything, but you might seal the ends of the hoses up just in case you change your mind down the road.
Willcox
Old Apr 10, 2011 | 12:32 PM
BKbroiler's Avatar
BKbroiler
Remove the evaporator off the firewall too. Get a new cover plate from acdelete.com. They fit nicely.
Old Apr 10, 2011 | 01:01 PM
johnt365's Avatar
johnt365
The a/c compressor and brackets were long gone from my car when I bought it. This year I finally removed the rest of the system and blocked it off with one of the a/c delete plates. I LOVE IT. There is so much real estate over there now. Headers, spark plugs, no problems.
When you put on your cover, you can use a 2 inch hole saw to relocate your resistor to the location in the pic below.
Old Apr 10, 2011 | 01:46 PM
mikejpss's Avatar
mikejpss
From: Where it's always hot as Hell-South Louisiana.
St. Jude Donor '07-'08-'09-'10-'11-'12-'13
$180 bucks ?????
Think I'll leave mine in... The a/c compressor doesn't cost any MORE than this........
Old Apr 10, 2011 | 03:24 PM
BKbroiler's Avatar
BKbroiler
Originally Posted by mikejpss
$180 bucks ?????
I didn't say it was cheap, just nice.
Old Apr 11, 2011 | 08:00 PM
UCVette's Avatar
UCVette
I may remove. That is a lot of money but it looks good. How hard is it to remove?
Old Apr 11, 2011 | 08:17 PM
BKbroiler's Avatar
BKbroiler
Not too bad to remove. There is an access panel just behind the wheel well, on the bottom. Remove that, remove the separator - looks like an aluminum can. Then unbolt the evap housing. There is one bolt inside the car. Pull the carpet back from under the dashboard on the pass side and you'll see it. You have to locate and drill the holes in the new cover. Mount your original fan. That's most of it.
Old Oct 5, 2012 | 12:10 PM
mk8035's Avatar
mk8035
Default Remove the evaporator
the evaporator has a Small looking radator in it? Is it for the A/C? If so i can get rid of? And if so were the hell is the heater core?
Old Oct 5, 2012 | 01:04 PM
pippo350's Avatar
pippo350
On my '81 I removed the entire sistem,you can check by your self my work:
http://forums.corvetteforum.com/c3-g...home-made.html
Old Oct 5, 2012 | 02:11 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by mk8035
...the evaporator has a Small looking radator in it? Is it for the A/C?...
No. It's your heater/defroster core. You need it if you want warm air for heating and defrosting.
Old Oct 5, 2012 | 02:55 PM
mk8035's Avatar
mk8035
Yep figured it out Heater core inside of the car.
To Removing A/C - questions
