Rack and Pinion u-joint problem
Old Apr 12, 2011 | 08:50 AM
moonsteel's Avatar
moonsteel
Holley HP EFI w/TPI
Default Rack and Pinion u-joint problem
I am installing the VBP rack attack and I can't slide the u-joint onto the steering column easily. Before I try and force it, is this common? Does something need to be done first?
Old Apr 12, 2011 | 10:04 AM
brando1118's Avatar
brando1118
It's all about the angle. Lube it up a bit with a little grease. Check for any damaged splines. It should go on with very little force.
Old Apr 12, 2011 | 02:44 PM
dduenkel's Avatar
dduenkel
The shaft on my steering column where the splines are was a little rusted... I took a steel wire brush and cleaned out the splines.. then put some grease on there and it went together easier. In the end I had to take a block of wood and a hammer to get it up all the way on there but it didnt take too much effort.
To Rack and Pinion u-joint problem
