C 3 cruise control - how to?
Old Apr 12, 2011 | 10:26 AM
shotgunvet's Avatar
shotgunvet
Default C 3 cruise control - how to?
I did a search first, and did not find any useful information.
Has anyone installed an aftermarket cruise control on a manual transmission C 3?
If so, what are the problems, whats a good brand, and ????
Thanks, Shotgunvet
Old Apr 13, 2011 | 09:10 AM
shotgunvet's Avatar
shotgunvet
Default cruise control
HMMM. guess not.
Old Apr 13, 2011 | 09:22 AM
Imo Apita's Avatar
Imo Apita
You need a little more patience, your post has been up less then 24 hrs.
I'm on this board like multiple times a day, but not everybody is.
Some of the guru's around here don't show up but once a week or so.
You'll get plenty of answers if you give it some more time.
Old Apr 14, 2011 | 03:30 PM
Ak. Mal's Avatar
Ak. Mal
From: Kansas City, MO ...I'd like to go fishing and catch a fishstick. That'd be convenient. - Mitch Hedberg
I'm interested in this as well.
Old Apr 14, 2011 | 04:33 PM
c3corvette77's Avatar
c3corvette77
I saw an artice on this in Corvette magazine a year or 2 ago. They installed cruise control from Dakota Digital in a manual trans Vette. I have the magazine somewhere but it'll probaby be faster to find it on the internet.
Old Apr 14, 2011 | 04:51 PM
shrekviper's Avatar
shrekviper
I'm interested in seeing that article. This is what came up on a Google search.
http://www.dakotadigital.com/index.c...d=46/prd46.htm
Old Apr 14, 2011 | 05:02 PM
c3corvette77
I'll dig around for that magazine and let you know what month it was. Maybe I can scan it to a pdf. Let you know.
Old Apr 14, 2011 | 06:16 PM
shotgunvet's Avatar
shotgunvet
Thanks, I would love to see that article also.
I talked with Sasche Rod Shop, and they said it would be fairly easy, but you have to deactivate the controller before you push in the clutch, or its full tilt boogie on the RPM's. It seems like there ought to be a way to kill it when the clutch is depressed, just like tapping the brake in my truck.
Old Apr 14, 2011 | 07:25 PM
oldboat's Avatar
oldboat
i am running a rostra universal electronic cruise control in my 69. it is on a 700r4 automatic so i disconnected the tach cable to keep it from disengaging when the trans downshifts on a steep hill. other than that no problems at all. i have it mounted below the vacuum canister on the drivers side. i use the speed sensor that mounts between the trans and the speedo cable. works great. don't see why it wouldn't work just as well on a manual trans.
Old Apr 14, 2011 | 10:08 PM
c3corvette77
Ok sports fans, I found it. March 2008 issue of Corvette Enthusiast. They install a Dakota Digital cruise control kit in a 79. It says it can be installed in any Vette from 53 to 96. It uses a vehicle speed sensor installed in line with the speedo cable. There are 2 switches to disable the cruise, one on the brake pedal and 1 on the clutch. Pushing either cancels cruise. I'll see if I can scan this article into a pdf.
Old Apr 14, 2011 | 10:11 PM
eagle275's Avatar
eagle275
Old Apr 14, 2011 | 10:23 PM
toyvet1's Avatar
toyvet1
I have a 1979 factory four speed car that i just installed a factory set up. All that need modifing was correct speedo cables. It works great, just tap the brake before pushing in the clutch. Plus it look factory. Ive been using it for 32 years with out a hitch.
Old Apr 15, 2011 | 12:21 PM
c3corvette77
I have the article scanned into pdf. It's black and white but you'll get the idea. PM me your email and I'll send it to you.
To C 3 cruise control - how to?
