bleeding problem
Old Apr 13, 2011 | 08:55 PM
7t9l82's Avatar
7t9l82
Default bleeding problem
i got 3 wheels gravity bled but the drivers rear no matter how i try to bleed it nothing. I'm going to pull that hose to check it but i would think there should be some flow thru it with just gravity and no pressure. the right rear took some time and now flows well all calipers are fresh o ring rebuilds
Old Apr 14, 2011 | 08:13 PM
LB66383's Avatar
LB66383
How old are the flex hoses? It could be closed down oin the inside. Does any fluid come out of the caliper if you press on the brake pedal?
Old Apr 14, 2011 | 08:18 PM
7t9l82's Avatar
7t9l82
yes that is what happened, the inside of the hose collapsed. i couldn't believe that no fluid would come thru pressure or gravity but that was it thanks
To bleeding problem
