excessive oil on valve stems?
Old Apr 14, 2011 | 06:02 PM
another-user's Avatar
another-user
Default excessive oil on valve stems?
so, i pulled the manifolds off this afternoon and saw this. i cant imagine its a good thing. cylinder 7 is the worst.
1
3/5 7 from another angle
the other side looks dry on 4-8, and just a little bit of oil on 2.
Old Apr 14, 2011 | 06:09 PM
Imo Apita's Avatar
Imo Apita
I'm no expert but that doesn't look too bad, I've seen worse.
Is it an automatic or stickshift?
Old Apr 14, 2011 | 06:14 PM
another-user
its a stick.
Old Apr 15, 2011 | 09:47 PM
Tim81's Avatar
Tim81
Does the car smoke when you first start it up in the morning? My guess is worn valve seals, guides or both. I'm no expert...
Old Apr 15, 2011 | 10:04 PM
another-user
i honestly cant remember, its been about 6 months since i parked it. if it did smoke, it was only a little, and only for a moment or two.
Old Apr 16, 2011 | 08:38 AM
Tim81's Avatar
Tim81
Thats a classic sign of bad seals or guides. Hopefully someone with more knowledge will comment. Good Luck
Old Apr 23, 2011 | 04:33 PM
another-user
bump
Old Apr 23, 2011 | 05:55 PM
Imo Apita's Avatar
Imo Apita
The reason I asked you stick or automatic is because if you downshift a lot with a stick it causes some oil to get past the rings and it gets burned on the next stroke.
Never stopped me from downshifting a lot but that's what it does.
Like I said earlier they look ok to me but no 7 may need some new valve seals. If it runs fine don't fix it except 7.
Old Apr 23, 2011 | 05:59 PM
another-user
ive never worked on heads before, is this something easy-ish to do? special tools needed?
Old Apr 23, 2011 | 06:06 PM
rugerm44's Avatar
rugerm44
How many miles on engine.valve stem seals are not that hard to replace.the do wear and crack over time.if it smokes on startup and quits after a minute its probably the seals.
Old Apr 23, 2011 | 06:15 PM
another-user
theyre original, so...75k-ish miles on them. from what i remember, it smokes for a few moments, and then clears up.
Old Apr 25, 2011 | 07:43 AM
jackson's Avatar
jackson
install new seals on all 16 ... not hard to do ... I did mine w/ Both Orings & Umbrellas ... and replied to a VS seal thread here where I described an easier & much faster method. Search.
You might also consider ... intake manifold gasket(s) may also be leaking ... sucking oil fom valley into port(s).
To excessive oil on valve stems?
