oil pan
Old Apr 15, 2011 | 04:03 PM
painterman52's Avatar
painterman52
Default oil pan
I think I have the wrong oil pan, I`ve got a persistant leak that I need to fix. I just want a stock type pan. I`ve got a 383 built with a 69 4 bolt block. Anyone have a suggestion with a part number.
Old Apr 15, 2011 | 09:16 PM
blue427's Avatar
blue427
you don't mention where your pan is leaking from,it may be a gasket or bent rail.If you don't know which pan you have make sure the one you buy is the same depth as your old one so your oil pump sits at the right distance from your oil pan.My suggestion is to call Summit or Jegs and get a matching pickup and pan.
