Refinishing Aluminium Wheels
Old Apr 28, 2002 | 03:41 PM
stingonbay's Avatar
stingonbay
5th Gear
Default Re: Refinishing Aluminium Wheels (Justin79-L-82)
After you have wet sanded all the old clear off the wheels . Jewlers rouge works well with a wool polishing pad on a drill. You can get small packages at a hardware store with different compounds. Its a lot of work. but well worth it in the end.
Old Apr 28, 2002 | 03:49 PM
Justin79-L-82's Avatar
Justin79-L-82
Default Re: Refinishing Aluminium Wheels (stingonbay)
After i sanded them i just used a handdrill with a polishing head on it.. it worked really well with mothers mag polish.. :chevy
Old Apr 28, 2002 | 05:51 PM
razz1980's Avatar
razz1980
i seen a red vette with the slots painted the same colour red..i thought it looked very kool..did see a vette done the same in yellow but the efect was oposite it looked like poopie ..i think it depends on the colour with darker colours looking better :p:
Old Apr 29, 2002 | 02:21 AM
Justin79-L-82
Default Re: Refinishing Aluminium Wheels (razz1980)
After sanding and polishing your wheels did you guys spray any kind of clear coat on it or just leave it after you polished it?
Old Apr 29, 2002 | 07:40 AM
Nomad78SA's Avatar
Nomad78SA
Where do you get the polishing pads or buffers to go on the drill? What size are they? I went to Sears looking for some kind of polishing pad kit but did not see anything but big buffing pads. Can someone point me in the right direction or post some pics of the buffing pads or tool. I started cleaning the road grime off the inside of the rims and had to use a brass wire wheel to even phase it, but would like to try and polish the rims out myself.
Neil in Tenn
Old Apr 29, 2002 | 09:54 AM
Captain Morgan's Avatar
Captain Morgan
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
Default Re: Refinishing Aluminium Wheels (Nomad78SA)
Justin,
You can clear coat the wheels, but you will end up with yellowing, chipping clear coat a few years down the road. Of course, if you don't clear coat them, you will need to maintain them with a little aluminum polish occasionally. It all depends on which you prefer, routine maintenance, or re-finishing your wheels again in a few years. Of course, if you don't keep up with the routine maintenance, you'll end up having to refinish them anyway. Your choice.
Neil,
Check with a paint and body shop, or maybe even your local auto parts store. They should be able to tell you where to find the stuff you're looking for.
Old Apr 29, 2002 | 03:17 PM
Justin79-L-82
Default Re: Refinishing Aluminium Wheels (sharklover)
Niel... I just bought a polishing head from canadian tire...it came with an attachment to hold the pad to the drill, a backing, and a polishing bonnet to fit over the backing... The whole thing is about 6 inches in diameter and are pretty easy to find at any store with a hardwear department, really cheap too. i think it was 5$... prolly like .50 cents in the states because our exchange is so bad :lol:
Old Apr 29, 2002 | 06:04 PM
Pete79L82's Avatar
Pete79L82
Neil in Tenn
Try a local truck stop. With the amount of polished aluminum that Semi's have on them most truck stop's carry all the stuff to polish them or will know where you can get the stuff. They usually have jewelers rouge and airway buffing wheels and about anything else you can think of to polish aluminum or stainless. Also try a Peterbilt or Kenworth dealer.
