'81 blower motor help...
Unfortunately, the heater fans will NOT come on. Fuses have been replaced under the dash, electrical connectors on the control switch have been lightly sanded and reconnected, no joy. However, what I did notice is the vacuum line connector fits a bit looser compared to the stock vacuum control switch and I can hear the vacuum leak hissing away.
Before I start trying to figure out what wires to trace, relays to replace, and how to bypass the controls and just get 12V to the blower motor, would a leaking vacuum control switch keep the fans from coming on at all?
How is the blower relay on the engine side?
If you put the vaccum connector back on cockeyed it could jam it.
It should not be hissing all the time.
The vacuum system controls the heater box doors, that directs air to either the floor, dash vents or defroster vent. I can't recall any correlation between the fan switch and the vacuum. I'll try to dig out my 81 Shop Manual a little later, and see if there is any reason why one, could effect the other.
My thought is if it was off when it broke, the vacuum leak may not let it go to any of the on positions so the fan will never go on, regardless of the hi/low position. I just don't know if this is wishful thinking or if something else really is broken.
How can I test the blower relay?
edit: My car has A/C (which lost it's charge 10+ years ago), if that makes any difference.
It was the relay. No idea how it happened or how it could possibly every have worked - one of the blade connectors was bent and not going into the connector slot. I don't remember ever taking the relay off, no reason to for anything I've done, but the heater did work in the past...
Hopefully the vacuum leak is resolved as well. I couldn't get a good seal no matter how tight I pushed the connector on, so I bubba'd it a bit by putting a small dab of silicon caulking at the base of the posts. Haven't checked since I left it to dry, but it should be enough to seal it and still be easy enough to pull apart in the future if I ever need to.
FWIW, I pulled a couple fuses years ago when I couldn't figure out a slow battery drain. I thought that was part of why the heater fan wouldn't come on - nope. Turns out the drain was the dome light timer - figured it out by searching this forum, you guys are great.
