What is the best way of to safely remove it from my door without damaging the paint? The drop is so small that it is probably only noticeable to me, but I want to remove it from the paint.
Re: It is either dried pine sap or super glue (virtue4u)
I've taken sap off while washing the car. Just scrap it with my thumb nail, while there's soap and water on the spot to kind of "lubricate" the area around it. Sometimes have to polish the area afterward, but it doesn't scrape the paint.
Might want to try the "Bug and Tar" remover you can buy at the auto parts store. WARNING I dont' know how it works on fiberglass. Maybe try a hidden spot somewhere first to make sure it doesn't react.
I have removed pitch using paint thinner. You may need to wax the area again after. Try it in an inconspicuous area first. If it is super glue, try to shave it off with a razor blade . . .
I've tried the thumbnail and soap and water. This stuff doesn't budge. I might go with adhesive remover or kerosene next. I will try it out on an inconspicuous place first. The spots are so small that I may not even worry about. It isn't even obvious to me unless I get about 4" from it. I found it while washing the car.
