Corvette Composite Rear Spring
Old Apr 19, 2011 | 04:05 AM
Ralphbf's Avatar
Ralphbf
Default Corvette Composite Rear Spring
Will a Corvette Composite Rear Spring from a 1967 fit a 1975?
It would be nice if it would.
Ralph
Old Apr 19, 2011 | 08:33 AM
wombvette's Avatar
wombvette
Ralph
And what composite spring was on a 67? Unless the composite is steel and rubber, it never happened.
Old Apr 19, 2011 | 08:40 AM
redvetracr's Avatar
redvetracr
one someone replaced....
Old Apr 19, 2011 | 09:19 AM
63split63's Avatar
63split63
This response must be from the NCRS cops !
He asked if it would fit, not if it would pass judging at Bloomington .
Bill
Old Apr 19, 2011 | 09:58 AM
wombvette's Avatar
wombvette
Bill
Then how in the crap are we supposed to know if it will fit. If its been changed, we don't know what it is. The early spring is not as wide as the later C3s but you can make any of them fit, if you change enough stuff. How much stuff has been changed? You know?
Old Apr 19, 2011 | 10:06 AM
Paul L's Avatar
Paul L
If it is 2 1/4" wide then yes.
Old Apr 19, 2011 | 10:12 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
...Will a Corvette Composite Rear Spring from a 1967 fit a 1975?...It would be nice if it would...
Possibly. My Corvette Illustrated Parts Catalogue lists the same rear spring 63-77. Do you know who made the fiberglass spring? You could check application with the manufacturer.
63Split63: NCRS and Bloomington are two different things.
Old Apr 19, 2011 | 11:00 AM
63split63's Avatar
63split63
Default Negative Posts
I do know that but thanks anyway.
I was just making a point about the neg type of post that hinders people from asking questions on the board .
Bill
Old Apr 19, 2011 | 12:05 PM
Ralphbf's Avatar
Ralphbf
This is a VBP 360 # composite rear spring.
was designed for a 1963 1964 1964 1967 Corvette.
Is the spring to heavy for a cruiser?
Ralph
Old Apr 19, 2011 | 12:08 PM
Van Steel's Avatar
Van Steel
Premium Supporting Vendor
yes it will work in a 75. GM didn't change the rear end cover until 78. I think it will be a little still for a cruiser. 330 would probably be a better spring rate to have.
Old Apr 19, 2011 | 02:49 PM
Ralphbf's Avatar
Ralphbf
It's new and they are asking $125.oo
To Corvette Composite Rear Spring
