'79 Automatic Reverse Lights Are Not Working....
Old Apr 23, 2011 | 09:05 AM
jeff79''s Avatar
jeff79'
St. Jude Donor '10
Default '79 Automatic Reverse Lights Are Not Working....
What could it be, before I start messing with things that I have no clue about ?
Old Apr 23, 2011 | 09:20 AM
dar322's Avatar
dar322
St. Jude Donor '12-'13
before ripping the car apart, check the bulbs first.
Old Apr 23, 2011 | 10:35 AM
jeff79''s Avatar
jeff79'
St. Jude Donor '10
O.K.....Anyone out there have a decent diagram of where the Neutral Safety/ Back-Up Switch goes ? My '79 shop manual is somewhat vague on the subject. In the console ?....
Old Apr 23, 2011 | 10:43 AM
wnmech's Avatar
wnmech
Here is a link to pappawana's post. Send him a pm and he will forward the wiring diagram of your car to your email.
http://forums.corvetteforum.com/c3-g...or-anyone.html
Old Apr 23, 2011 | 12:10 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Under the console, on the shifter.
Old Apr 23, 2011 | 12:16 PM
speedreed8's Avatar
speedreed8
first check bulbs of course, check frame ground wire for bulb sockets, should be on frame left rear. the neutral safety switch may be out of adjustment. it has two screws and slots so it can be moved. its mounted on right side of shifter under console, you have to remove pass. seat and left side console cover. to get at it. here are a couple of simple diagrams for it.
http://www.corvetteforum.net/c3/tune.../index11.shtml
the bottom diagram shows neutral safety switch. and backup light connector (make sure plug hasnt come loose.)
http://www.corvetteforum.net/c3/tune...l/index9.shtml
easymike has a better pic above.!!
Old Apr 23, 2011 | 01:28 PM
jeff79''s Avatar
jeff79'
St. Jude Donor '10
Thanks guys.....I'll start diggin.
Old Apr 23, 2011 | 04:23 PM
jeff79''s Avatar
jeff79'
St. Jude Donor '10
And the rear screw comes out with what tool ??? Unbelievable...It's basically inaccessible....
Old Apr 23, 2011 | 04:28 PM
jeff79''s Avatar
jeff79'
St. Jude Donor '10
The turn signals work, so I assume the ground is ok....Right ?
The plugs are on tightly
I put it in Reverse with the key forward, and jiggled the switch, and nada...
Should I now assume that the switch is shot ?
I'll do the obvious now and check the bulbs, but what are the odds that both are out ?
Old Apr 23, 2011 | 04:40 PM
jeff79''s Avatar
jeff79'
St. Jude Donor '10
First check the bulbs.....Did I miss that part ? I'm off to the store to get some....They're fried...:o
To '79 Automatic Reverse Lights Are Not Working....
