Would a Free-wheeling A6 A/C Compressor Seize?
Old Apr 23, 2011 | 03:24 PM
Paul L's Avatar
Paul L
Default Would a Free-wheeling A6 A/C Compressor Seize?
Right now the drive belt is off my 1974 A6 A/C compressor. The A/C has been non-functional since I bought the car a couple of years ago. I disconnected and tucked away the electrical connections so they remain intact.
Being a convertible I generally drive with the top down (unless it rains) and have no need for A/C. In fact I can count on one hand the number of days in the past few summers when temps went over 30*C (86*F): this is not a heat zone. On cooler days I just flick on the heater.
I had thoughts of removing the A/C system but that really takes away from a car's attributes, even if not working. I also had thoughts of having it repaired but given the possibility of very limited use, and the very substantial costs I might face including mandated R-134 conversion, that does not appeal.
But just to give the "appearance" of the car being whole I was thinking of putting the A/C belt back on. I have a new one in the basement inventory. The compressor pulley moves freely by hand so it is still operable in that sense. If the belt is put back on is there any chance the compressor, although free-wheeling and with no electrical power, will seize even without the clutches kicking in as with normal use?
Appreciate your comments!
Old Apr 23, 2011 | 03:31 PM
mikejpss's Avatar
mikejpss
From: Where it's always hot as Hell-South Louisiana.
St. Jude Donor '07-'08-'09-'10-'11-'12-'13
It takes voltage applied to the clutch to make the compressor crankshaft begin to turn. The answer is :NO.....Just make sure you tuck the electrical connection (unplugged) away from the compressor.
There will be a minimal h.p. loss just by rotating the belt on the compressor. I doubt that the loss could be measured since it's so small. Just make sure the compressor will never see a voltage signal to pull the clutch in.
It's all in viewpoint, as I just took all my stuff off the engine when I put in a new crate motor. Left the evap coil and box, everything else is toast...
Old Apr 23, 2011 | 03:36 PM
Paul L's Avatar
Paul L
The electrical connection is disconnected but intact and hidden in a nearby wiring harness with harness tape. Same for the wiring for the idle stop solenoid on the carb (the solenoid is actually removed and stored with other spare parts on a shelf).
Old Apr 24, 2011 | 12:24 AM
chevymans 77's Avatar
chevymans 77
St. Jude Donor '05-'06,'11,'13-'14,'16,'18,'19,'24, '25
The pulley is on a bearing mounted to the front of the compressor.
It is possible that this bearing could fail and seize while not using the compressor.
I've changed a few of these bearings over the years; it’s not a hard job with the right tools.
The compressor will have no effect on the operation of the pulley as long as the clutch is not energized.
After reading your question again I'm not sure I understand what you’re asking. Are you asking if the compressor could seize from not using it or are you concerned that the pulley could seize from having the belt spinning it?
Neal
Old Apr 24, 2011 | 07:05 AM
Paul L's Avatar
Paul L
Neal
Neal,
The latter. Is there a possibility that the pulley could seize from having the belt turning it (but no load from the clutch).
Old Apr 24, 2011 | 07:30 AM
Chromie69's Avatar
Chromie69
From what I have read so far you are worried about the belt burning off..if that's your only worry about having a stock looking car replace the bearing under the pulley..cheap insurance and easy to do.
Old Apr 24, 2011 | 07:51 AM
mds3013's Avatar
mds3013
Hey Paul, all the guys are correct. Put the belt on it and see if the clutch bearing is noisey. They normally schreech for several miles/days before they lock up. In Canada, it is mandatory to convert to R-134A? mike...
Old Apr 24, 2011 | 09:34 AM
chevymans 77
thanks for clearing that up for me,
Yes the pulley bearing can still fail
Neal
Old Apr 24, 2011 | 10:19 AM
Paul L's Avatar
Paul L
Neal
I'll give it a try and see what happens.
Old Apr 24, 2011 | 11:42 AM
Taijutsu's Avatar
Taijutsu
Default Same Problem!
I have had two compressors lock up on my 74. The first time was bc it was not "cycling" properly?
The next was a mystery. Yesterday I wanted to fire off the beast for the spring. No starting and the best is squealing. I'm going to pull the best this morning and try again. There has to be a fix that lasts longer?
I have heard forum members say the compressor is old, big and heavy, but it is supposed to last. Not in my experience.
I'm not fixing this old outdated system until I can do it right. A whoe new aftermarket system is out of the question for now. I was hoping to get off w/new compressor? LOL We shall see.
R
Old Apr 24, 2011 | 12:14 PM
noonie's Avatar
noonie
Many of the a/c belts had been removed because the pulley bearings were bad, not the compressor itself. You can test the pulley bearing by just turning it by hand to see if if it feels smooth.
If you are having compressors seize, then it either wasn't evacuated properly for moisture and then filled properly or the system had a leak.
Unlike most modern compressors, the a6 has an oil reservoir which helps in lubrication.
A later style seal can also be used to prevent the old tell tale front seal seepage problem. The downside is the shaft will eventually wear instead of just the seal.
They are still used in heavy duty applications.
Old Apr 24, 2011 | 12:51 PM
Taijutsu's Avatar
Taijutsu
Default Lack of Use?
I was told that if I just ran the AC more often, the system would hold coolant and need less work. I will check the bearings later today.
I agree that the car should be run, but sometimes that is not pratical.
I still want something that holds up better.
R
Old Apr 24, 2011 | 12:58 PM
Paul L's Avatar
Paul L
If I were to get serious about the A/C I would consider a Sanden compressor and the pressure hoses needed. It seems that Eckler's sells a light-weight replacement for the A6 - physically identical - but the $398 price does not appeal to me.
http://www.ecklers.com/corvette-comp...1963-1976.html
Old Apr 24, 2011 | 04:41 PM
Paul L's Avatar
Paul L
The belt (Gates #15585, 85.5") is on and all is quiet. I will cross my fingers for the summer. It is nice to have the engine "complete" looking if not entirely functional.
To Would a Free-wheeling A6 A/C Compressor Seize?
