Need advice on what could have gone wrong...
Old Apr 23, 2011 | 10:47 PM
blasmartinez's Avatar
blasmartinez
Default Need advice on what could have gone wrong...
Today I was driving my 79 vette down the hwy and suddenly it began to smoke. I pulled over and popped the hood and to my amazement the PCV Valve had blown and the air breather had blown off. It looked like oil and coolant had blown everyone it was a slightly brown watery substance so I am assuming thats what it was. After having the vette towed back to my garage I noticed that there was a small gash in the oil pan that looks like it was made from the inside out... what could have caused this? could it have just been normal wear and tear? Any advice before I dig into the oil pan would be great.
Old Apr 23, 2011 | 11:07 PM
BB68Vett's Avatar
BB68Vett
Doesn't sound good. Not sure about the pcv and breather issue, but you may have thrown a rod which impacted the inside of the oil pan. Drop the pan, take some pics and post them. Then you can get advice on next steps.
Old Apr 23, 2011 | 11:13 PM
Timsride's Avatar
Timsride
I fear you have blown your motor. Hopefully its not as bad as it sounds.
Old Apr 23, 2011 | 11:16 PM
rcread's Avatar
rcread
My bet is on catastrophic failure.
My advice would be prayer. I'm crossing my fingers for you.
Old Apr 24, 2011 | 12:27 AM
procketus's Avatar
procketus
C4 of Year Finalist (appearance mods) 2019
2017 C4 of Year Finalist
Sounds like the motor went
Old Apr 24, 2011 | 01:12 AM
oldboat's Avatar
oldboat
doesn't sound like a catastrophic failure. if you had thrown a rod it would have made one hell of a lot of noise. from your description it sounds like the engine was still running when you pulled over.
sounds more like fuel got into the pan or lifter valley and ignited creating enough pressure to blow off the pcv and create the fracture in the pan.
Old Apr 24, 2011 | 08:42 AM
Indiancreek's Avatar
Indiancreek
Suspect the engine will need to be rebuilt. How many miles on the engine?
The dent in the pan will be from one of the rods. That's the second post this morning that sounds that way.
Old Apr 24, 2011 | 08:49 AM
Indiancreek
That brown milkshake looking stuff is the result of oil and coolant getting mixed. Not a good sign.
Old Apr 24, 2011 | 08:53 AM
c3corvettes's Avatar
c3corvettes
Blown rod on the down stroke.
Old Apr 24, 2011 | 10:54 AM
blasmartinez
Yeah the engine was still running and I was able to shut it off before any rattling or cranking sounds could be heard. I kind of figured the oil was gone because the pressure went completely down so i quickly shut off the engine. We did turn the key afterward to see if the engine would turn over, and the engine will turn over but have not wanted to start the engine completely sine there is no oil...
Old Apr 24, 2011 | 10:55 AM
blasmartinez
I kind of figured that, but don't know how they mixed. Check the coolant tank still is full unless all the coolant from the radiator is gone...
Old Apr 24, 2011 | 10:58 AM
oldboat's Avatar
oldboat
please keep us informed. this sounds really interesting.
Old Apr 24, 2011 | 12:20 PM
Indiancreek
If there is a hole in the pan, the bottom end is toast. If there is coolant in the oil, I suspect a hole in a cylinder wall where the coolant and oil mixed.
A head gasket could do that, but that doesn't explain the hole in the pan. Pump air into each cylinder, one at a time. You'll find one at least that will just keep on taking air. That will be the one that no longer has a piston I think. If you have a siezed piston, the air may force it past the hole in the cylinder wall. One or mor cylinders will sound like an open air hose, just blowing air. You can use any kind of air nozzle, packed with a rag around the plug hole.
Old Apr 24, 2011 | 01:18 PM
blasmartinez
well there is coolant in the oil pan what is the possibility the water jacket busted?
Old Apr 24, 2011 | 01:26 PM
mar's Avatar
mar
...any engine work on it lately???
Old Apr 24, 2011 | 01:38 PM
blasmartinez
Only engine work done to it lately was park plugs a wires changed and then i took it to a local national auto mechanic franchise so they could flush the radiator and while i was at it I decided to have them change the oil. Thats when they ended up putting synthetic oil without me knowing...
And thats about it for engine work done lately. Kind of pist off at the mechanic shop i took it too... never again
Old Apr 24, 2011 | 01:46 PM
rcread's Avatar
rcread
When you build your new engine, I would recommend using synthetic after break-in.
To Need advice on what could have gone wrong...
Old Apr 24, 2011 | 02:04 PM
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
First thing I would is pull the pan, if you thru a rod the motor is toast
*I put this on all my posts: Please post back to those who helped you, the final outcome of your initial post
Old Apr 24, 2011 | 02:41 PM
blasmartinez
So if I thru a rod, there is no hope to try and fix the engine?
Old Apr 24, 2011 | 02:50 PM
mds3013's Avatar
mds3013
If the block is not cracked it should be reuseable. The crank, rods, pistons and cam may not be. I repaired a Ford 427 side oiler once that twisted a Lemans rod and took a 2in. chunk out of the oil pan rail. Hopefully this is not what you have. mike...
