80 Anti Theft System
Old Apr 18, 2002 | 09:53 PM
8T8T2's Avatar
8T8T2
Default 80 Anti Theft System
Last year when I bought her noticed the alarm horn was disconnected. Previous owner said it would go off for no reason. So today I thought it should be in working order. Hooked a 12V light on the horn leads and started trouble shooting problem. All switches are in working order[t-tops, doors, hood] but found the driver side door lock real touchy. After turning the key counter-clockwise to unlock door and disarm system, alarm would still go off when door was opened. All it took was a very small amount of rotation clock-wise before removing the key and it would work fine. It seems there should be a lot more tolerance with key position to arm the system than what there is now.
The question I have, and before I remove the door panel, is this something that is adjustable such as a micro-switch mounted to the door lock or possibly internal of the locking mechanism? Can this be repaired or does it need to be replaced?
Thanks :confused:
Old Apr 18, 2002 | 11:07 PM
PROSOUTH's Avatar
PROSOUTH
From: Manchester, Dead Center in the Middle of TN 25 miles to Jack Daniels,10 miles to Geo Dickle, and .8 mile from the Liquor Store at I-24 Exit 114
St. Jude Donor '05
Default Re: 80 Anti Theft System (82zoom)
I think it is in the drivers door lock & switch. Mine does the same thing. It's not real bad but it does the exact same thing ocasionally.
Let me know if you figure it out. Thanks JIM
Old Apr 19, 2002 | 11:35 AM
8T8T2's Avatar
8T8T2
Has anyone worked on this before....Please.....
To 80 Anti Theft System
