engine vacuum
Old Apr 26, 2011 | 09:24 PM
Ron 17265's Avatar
Ron 17265
1st Gear
Default engine vacuum
I'm looking for a vacuum diagram for under the hood of my wife's "77". How the breather,PCV valve,EFE,EGR,and other componets are connected. My Corvette Central Corvette assembly instruction manual has alot of pages stamped (waiting layout approval) and some stamped (canceled). I also have a Haynes Repair Manual. When I try to extrapolate them and pictures from catalogs it gets quite confusing. Please some one help me. Thanks Ron 17265
Old Apr 28, 2011 | 02:40 PM
CorvetteCentral.com's Avatar
CorvetteCentral.com
Platinum Supporting Vendor
Hi Ron -
From the 1977 Factory Assembly manual:
Section, Sheet(s) Diagram
B01-B12, 44 Washer, windshield
B01-B12, 59-63.5 HVAC
5G, 2 power brake vacuum
6H, 1 PCV
6L, 3, 4, 5 Vacuum tap, EGR and controls
6M, 2 Choke
6M, 4 Air cleaner heat stove, vacuum source
6N, 5 Cruise control
6T, 2 A.I.R. Divertor valve
8B, 1 fuel vapor return to tank
8D, 1, 2 fuel vapor recovery canister
8D, 3 Vapor recovery lines to tank
12C, 7, 8, 9 Headlight vacuum
Of these pages, 3 are “awaiting layout approval” and one is “cancelled”
Hope this helps.
Old Apr 28, 2011 | 04:06 PM
Duke94's Avatar
Duke94
Here's the non-engine vacuum diagrams.
Gary
http://willcoxcorvette.com/instructi...ted_080509.pdf
To engine vacuum
