no its not stright forward swap u need to mod your trany cross member or by another one also u need to shorten your drive shaft ,,, if u can get 200r4 that will be allmost easy swap
That's one of the weaker 700's, look for an '89 - '92.
Easy way to identify the better ones is that the casting lines run through the coolant line bosses.
It's a $500.00 Tranny that works good. I drove the car.
I'm putting out less than 350 hp and the car is just a cruiser.
What was the weak spot in the Tranny?
I swapped mine for a later better core. I think I have a 89 or 90 core. I think the 87-92 were the stronger ones. I may be wrong. The one in my 82 had originally been replaced. It was stamped remanufactured for GM on the side. But I opted for a beefed up 700 in a later core due to my engine upgrade. I still have the old 700r, it worked fine, and its for sale.
I have a 700R4 in my '79. I understand the 200-4R is an easier swap but the 700R4 is no big deal if you have any mechanical ability at all. You don't need to change the crossmember, and you can buy the parts to bolt it up as GM used the 700R4 in the Corvette in '82. You just have to make sure you get the right tailshaft housing.
You will have to shorten the driveshaft but that's no big deal. Measure what you need and take it to a machine shop with driveshaft experience. The biggest problem is routing the exhaust. The 700 is wider than the TH350 just in front of the crossmember and its a challenge to get the pipe past the trans and through the crossmember. I modified my crossmember to move the exhaust hole outboard about 2". You also have to move the park brake cable pulley. Just cut it off, move it to where it works and weld it back on.
You'll love the swap. I went from 16 mpg to 25 (imperial gallons). Much more driveable on the highway.
