Head Warpage
Old Apr 27, 2011 | 09:00 AM
63split63's Avatar
63split63
Default Head Warpage
Goodmorning. I am rebuilding a 71 small block with origonal cast heads. Can anyone tell me how much warpage is acceptable with fel-pro .040 composition head gaskets . The block deck is good.
Thanks Bill
Old Apr 27, 2011 | 12:28 PM
Manuel Azevedo's Avatar
Manuel Azevedo
Thanks Bill
NONE!! Let me say that yea that gasket will take up some warpage for sure. But think about this, the head was hot enough to warp so what do you think your valve seat run-out might be? Yea people who don't understand metal will say pour solvent in the port or chamber and see it they seal! Wrong, with enough seat spring pressure most out of round seats will seal ok at rest. Ever see a valve seat wider on one side than the other and the valve clearance was not that bad? And trying to lap a valve to seal is just bull also. You'll just trying to correct poor run-out with this procedure. If all is correct the valve will seal just right even with no valve springs installed. Your heads are in question here other wise you would not ask this question. I didn't even say anything about cracks here even. Get your heads checked out by a competent Machine Shop!! Good Luck!!
Old Apr 27, 2011 | 08:58 PM
63split63's Avatar
63split63
Default Ttt
Anyone else have an opinion on this ?
Bill
Old Apr 27, 2011 | 09:20 PM
tnovot's Avatar
tnovot
I also say have the heads checked out at a shop. No sense going through all the expense and work of rebuilding an engine and then installing questionable heads which could come back to haunt you.
Terry
Old Apr 27, 2011 | 09:25 PM
63split63's Avatar
63split63
Default .005
I should have mentioned that I had them checked and 1 is .005 " warped .
Is that too much for composition gaskets?
Bill
Old Apr 28, 2011 | 07:47 AM
jackson's Avatar
jackson
Bill
so long as seats&guides are OK ... then 0.005" warp will be too. Dunno how much if any your decks been cut? ... GM markets a nice composition gasket for sbc 350 ... 0.028" / 5.8cc ... p/n 10105117
Old Apr 28, 2011 | 08:38 AM
bashcraft's Avatar
bashcraft
Bill
Why would you not have them surfaced?
Old Apr 28, 2011 | 08:42 AM
Indiancreek's Avatar
Indiancreek
It's not that expensive to flatten them. How did you determine the .005 number? A machinist straight edge or a depth gage on a mill to be accurate in that regard. At .005 I'd be inclined to take care of them.
What shape are your valve guide in? While they are off do as much as you can to get them up to correct condition.
Check the guides, valve seals, check for flat surface and most of all have then magnafluxed or pressure tested.
I understand that the cash outlay begins to add up, but if you put the heads on without proper attention, as soon as an issue pops up you'll suspect the things that you didn't attend to while the heads are off.
If your .005 is between the cylinder area you don't have that much surface area for a gasket to maintain seal. That is often the area that has the warp. If the gasses begin to travel between two cylinders, they can cut a passage in the block deck surface that will require the block to be decked. There is a high temp. high pressure gas traveling between the cylinders and it can remove deck surface.
To Head Warpage
