oil filter
Old Apr 29, 2011 | 10:32 PM
bvectra's Avatar
bvectra
Default oil filter
I'm building a 383 stroker motor with a 7 quart oil pan and want to put on a long oil filter does anyone have a suggestion
Old Apr 30, 2011 | 12:51 AM
dar322's Avatar
dar322
St. Jude Donor '12-'13
have you tried Walmart's super duper automatic oil filter selection program in aisle 17? You punch in the make, model, yr, engine and viola...it gives you the top choices. For me I prefer the big Wix filter at Napa.
Old Apr 30, 2011 | 12:53 AM
TheSkunkWorks's Avatar
TheSkunkWorks
From: Graceland in a Not Correctly Restored Stingray
Not one of the big names in the filter industry by which many swear, but Moroso has a line of racing filters definitely worth a look IMCO for high-performance applications. #22461 is 2qt. and 8" long, while #22460 is the shorter extra-capacity version.
Old Apr 30, 2011 | 01:14 AM
restoman1's Avatar
restoman1
If it's stock 68 and later "spin-on" style, then you'll want one of the following:
Purolator - L40084
AC - PF932
Fram - PH373
Motorcraft - FL308
STP - S373
Deutsch - S2827
These are all 2 QT instead of the standard (short) 1 QT filters and you should be able to find at least one of them at your local auto parts store.
Ed
To oil filter
