Spark plug question Iridium? Platinum?
Old May 4, 2011 | 08:37 AM
Sigforty's Avatar
Sigforty
Cruise-In IX Veteran
I just run regular copper NGK plugs in my vettes. The only thing I use a fancier plug in is my 4x4 blazer since they are a pain to change.
Old May 4, 2011 | 09:01 AM
noonie's Avatar
noonie
I don't know what shape your engine is in, but if you are seeing deposits then the engine is either in poor shape or your heat range may be a little too cold to burn them off.
Check this, although using e10 makes it a little more difficult.
http://www.boschautoparts.com/Techni...kPlugFaces.pdf
Here is some more info on plugs
http://www.globaldenso.com/en/produc...log_eu_gbr.pdf
Frankly an engine doesn't care about the spark as long as it lites the mixture adequately. You can can use fancy plugs in an old carb engine or cheapo's in a new fi engine. It's really just a personal/economic choice.
I once lit the mixture with my finger tip accidentally bumping over an engine and it really hurt.
Old May 4, 2011 | 09:55 AM
boltnut's Avatar
boltnut
incorrect. do not use platinum plugs in your car if it was designed for standard....especially if you run MSD
Old May 4, 2011 | 11:20 AM
birdsmith's Avatar
birdsmith
Originally Posted by Lotus76
Thanks for everyone’s input.
I was not really looking for power gains. Although longer life would be a nice thing.
I was more concerned about keeping the plug clean and not fouled. I mentioned this was a original short block (never rebuilt) so I do get a little build up on the plugs over time.
I have seen demos (plug manufactures) that clams a stronger spark, less prone to foul or build up.
So I am asking the forum members for their advise about the platinum or Iridium plugs from that perspective.
Thanks John
The best way to prevent plug fouling is with an engine that doesn't pass oil into the combustion chambers and whose fuel/air mixture is properly dialed in. Combine that with a healthy ignition system and a set of properly selected cheapo plugs will last many thousands of miles. This is the primary reason why plugs in new cars last 100,000 miles and up-modern EFI systems meter fuel so accurately across the load and RPM range that unburned fuel deposits never accumulate on the plugs, and their computer-controlled, crank trigger, coil-in-head ignition systems complement the situation by providing perfectly accurate timing, lots of spark energy, and almost zero misfires. When C3 vettes were in production Formula 1 cars didn't have ignition systems as sophisticated as the cheapest beer-can econobox does today...no exaggeration, that is just how far the technology has advanced. Just make sure the carb is properly set up, and if you want the plugs to last install a decent ignition...Pertronix and MSD are the most popular ones out there because they're relatively cheap, easy to install, and they WORK. You can spend your $$$ on Kryptonite plugs if you wish but you really won't be gaining anything...
