wiper motor replacement 1981
Old May 7, 2011 | 03:12 PM
Gears5's Avatar
Gears5
7th Gear
Default wiper motor replacement 1981
I received a new ac delco motor assembly list for my vehicle
It has a extra red wire. What to do with????
Old motor 3 wiew plug, Ground, 1 red
New motor 4 prog pliug 2 tied together, 1 ground, 2 red wires
Reds together????
Help some one
Old Oct 8, 2011 | 03:56 PM
RHT's Avatar
RHT
Hi
Searching threads as I have the same issue - replacement motor ordered and is different to original.
Extra wires and additional prong to work out.
I assume the extra wires are for a washer pump so it may be OK to just secure them without using as the pump on my 78 is separate?
Appreciate any information.
Regards
Robert
Old Oct 8, 2011 | 08:29 PM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
Did you guys check your old motor to make sure it is working? I have a video on U tube that shows how to test it... In most cases the original motor is fine and the problem is somewhere else.
Where is the extra wire located? Can you post a picture of this and I'll see if I can help both of you.
Here is how you bench test the motor?
Old Oct 14, 2011 | 08:43 PM
RHT's Avatar
RHT
Ernie
Thanks for chiming in.
I've attached a photo of the old motor and new motor.
You can see the 2 extra red wires from the new motor.
I did check the old motor as per your instructions but it didn't fire up so I would think it is toast?
Old motor
New motor
Thanks for any advise given.
Regards
Robert
To wiper motor replacement 1981
