died and now will not start
Was driving my 71 stock 350 friday night it just died after about an hour of driving. It will turn over but not start. Fuel pump is working and I changed the fuel filter. The car started after I changed fuel filter then died after about 30 seconds. Where do I check next?
You have to start with the basics. A car needs fuel. spark, and compression to run. Look down the throat of the carb and work the throttle. Can you see a stream of fuel from the accelerator pump? If so, you have fuel. Next test for spark. Use your favorite technique - spark plug tester or pull a plug and use that. If you have both and the timing is right, check for compression, but that's pretty unlikely. Sounds like fuel or spark.
