short or long water pump?
Old May 9, 2011 | 09:06 AM
vetteguy75's Avatar
vetteguy75
LA Events Coordinator
Default short or long water pump?
I've searched the threads and can't seem to locate the answer....do SB 350 have a long water pump or short water pump AND how do you tell the difference?
Old May 9, 2011 | 09:15 AM
c3corvette77's Avatar
c3corvette77
350 chevys had both depending on the application. If the back of the water pump practically touches the timing chain cover it's a short water pump. If there about say 1/4 inch gap between the timing cover and the back of the water pump, it's a long.
Old May 9, 2011 | 12:18 PM
chevymans 77's Avatar
chevymans 77
St. Jude Donor '05-'06,'11,'13-'14,'16,'18,'19,'24, '25
All C3 vettes had short pumps
Old May 9, 2011 | 12:26 PM
Ironcross's Avatar
Ironcross
No factory Corvette engines used a 'long water pump including small blocks or big blocks of any year....
Old May 9, 2011 | 12:42 PM
71rdster's Avatar
71rdster
Gen 1 small block Corvettes from 1969 forward used a special "short" water pump specifically for Corvettes. The dimensions are slightly different than those of a standard short Chevy water pump. Using a standard short water pump on your Vette will cause your pulleys to be misaligned.
Old May 9, 2011 | 12:46 PM
pws69's Avatar
pws69
Chevy Water Pump Specifications
Short-Style Pump for most 1955-72 cars & trucks (5/8" pilot shaft)
• Fits all 1955-68 S/B Chevy passenger cars, 1969-70 350 c.i.d. Corvettes and 1955-72 light duty trucks. Has 3/4" ball/ball bearing.
• Dimension from block surface to hub: 5-5/8". Inlet diameter: 1.80".
Long-Style Pump for 1969-87 V8, 90° V6 & 1973-86 truck (5/8" pilot shaft)
• Fits all 1969-87 S/B Chevy or 90° V6 passenger cars and 1973-86 light duty trucks. Does not fit Corvettes (use #8810 or #8812) or late-model vehicles with serpentine accessory drive belts (use #8881). Has heavy-duty 3/4" ball/roller bearing.
• Dimension from block surface to hub: 6-15/16". Inlet diameter: 1.80".
Short-Style Pump for 1971-82 Corvettes 3/4" pilot shaft)
• Fits all 1971-82 S/B Corvettes. Comes with heavy-duty 3/4" ball/roller bearing.
• Dimension from block surface to hub: 5-13/16". Inlet diameter: 1.80".
Old May 9, 2011 | 01:02 PM
mikejpss's Avatar
mikejpss
From: Where it's always hot as Hell-South Louisiana.
St. Jude Donor '07-'08-'09-'10-'11-'12-'13
A Corvette water pump is a special application. when ordering a new one, specify make, model and year.
By the way, I have a brand new LONG style if anyone wants / needs it. pm me. free to good home, just pay shipping.
Old May 9, 2011 | 01:17 PM
qwank's Avatar
qwank
Does anyone make an aluminum water pump for our cars? next time I have mine off I want to replace it with one to save a little weight.
EDIT: i just found one. GM makes one Part number 19168604
Old May 10, 2011 | 10:30 PM
VCuomo's Avatar
VCuomo
Edelbrock also makes one.
Old May 11, 2011 | 12:02 AM
noonie's Avatar
noonie
The special corvette pump didn't start until 1971 and it is 0.17" longer than the severe duty short pump which was used in Corvettes up to 1970.
To short or long water pump?
