Steering feels notched
Old May 10, 2011 | 12:49 PM
radbme's Avatar
radbme
Default Steering feels notched
Just left and right of center my steering feels like it almost snaps into place. There's a little bit of play at center but more right or left and you can actually feel (lightly) and see the steering wheel click into a groove. Any ideas on what that could be? Thanks.
Old May 10, 2011 | 01:10 PM
Kevin_73's Avatar
Kevin_73
Cruise-In X Veteran
St. Jude Donor '09-'11
I'm not sure what you mean by "click into a groove", but otherwise it sounds like you might have either bad bearings in the steering column or a bad rag joint. Or both.
The rag joint is the coupler between the steering shaft and the steering box. Look just below the master cylinder and you will see it. Check the rubber disk for cracks or breaks.
If the rag joint looks OK you will need to inspect the steering column more closely.
Old May 10, 2011 | 01:55 PM
bashcraft's Avatar
bashcraft
Have you messed with the steering box adjustment?
Old May 10, 2011 | 02:34 PM
radbme's Avatar
radbme
Thanks for the help, Kevin. No I haven't mess with it yet.
Old May 10, 2011 | 03:22 PM
SanDiegoPaul's Avatar
SanDiegoPaul
From: San Diego - Deep Within The State of CONFUSION!
the very first thing to check is the rag joint (coupler)... And if that is good then you need reman gearbox.
Old May 10, 2011 | 07:28 PM
sly vette's Avatar
sly vette
I agree...If the joint is good the box is probably worn.
Old May 11, 2011 | 12:52 AM
Kevin_73's Avatar
Kevin_73
Cruise-In X Veteran
It very well could be the steering box, but if I understood the symptoms as he described them it sounded like the issue is probably between the steering box and the steering wheel.
I am hoping that he will find the problem there before having to go through the hassle of removing/rebuilding/replacing the steering box.
Old May 11, 2011 | 12:19 PM
radbme's Avatar
radbme
Thanks guys. I'll have to take a look at that joint this weekend. I hope it's not the box. Honestly the steering is fine it's just feels a little weird at a certain place.
Old May 11, 2011 | 05:23 PM
spinadog's Avatar
spinadog
should be 3 threads showing on the top adjuster for the steering box. Sure it hasn't been overadjusted? That would also give the notchy feeling too.
To Steering feels notched
