454 Alternator bracket
Old May 14, 2011 | 12:23 PM
mrfw's Avatar
mrfw
3rd Gear
Default 454 Alternator bracket
I am in the process of getting the 454 ready to install in my 72. I have the Alternator bracket that attaches to the head. Does anyone have a picture of the upper bracket installed.This is a non PS car and I am not hooking up the AC at this time. So it would be alternator only.Drivers side. Yes I have the short water pump. Thanks
Old May 14, 2011 | 03:43 PM
ajrothm's Avatar
ajrothm
I have plenty of pics but they are for a PS car and the brackets are completely different. Sorry man.
Old May 14, 2011 | 06:51 PM
johnmb's Avatar
johnmb
Yep, same here...sorry!
Old May 14, 2011 | 11:28 PM
Ben Lurkin's Avatar
Ben Lurkin
St. Jude Donor '09
Go here:
http://www.zip-corvette.com/ProductD...GR-SR&CTitle=&
click on the two technical diagrams on the right-hand side of the page. They should get you going.
Old May 17, 2011 | 10:08 PM
RickyBerg's Avatar
RickyBerg
This is how it looks on my car with PS.
Maybe the picture can be to some help..
Old May 17, 2011 | 11:34 PM
Ironcross's Avatar
Ironcross
Default 1968
The OE cast iron lower bracket bolts to the head, the upper adjusting arm attaches to the intake.....notice this is a non power car and the reference to the waterpump is easy, All correct Vettes use the short waterpump.....If this is a transplant engine with a long pump it could be from a passenger car as some years use the long pump....
Old May 17, 2011 | 11:49 PM
Ironcross's Avatar
Ironcross
Default 92 bucks!
By the way, the Zip bracket that 'Ben references is correct...however at 92 bucks its highway robbery....Camaros use the same bracket and are only 1/2 the price .......
Old May 18, 2011 | 09:19 AM
Zip Corvettes's Avatar
Zip Corvettes
Platinum Supporting Vendor
This is not the same bracket that is on a Camaro. A Camaro bracket will fit the Chevelle, Nova and maybe even a truck and El Camino, but it does not fit the Corvette.
I realize that it may seem expensive compared to what you USED to be able to buy them for a swap meets and 15 years ago when you could get them from GM. Although we do not make it, it took a small company to pay to have the molds built and to have these cast. That in itself is very expensive, so while they may be more than what they were 2 decades ago, it would be worse if no companies decided to make the investment to make these parts anymore, then you would looking for a used one where someone knows you can't buy these new and they would be $500, just like the big block A/C expansion tanks were until DeWitts decided to reproduce them. There is no such thing as Corvette Tax, there are just not allot of Corvettes so the price of producing the parts get spread out over less parts than say a Camaro whos parts also fit several other vehicle lines and the price gets spread over 10 times the amount of parts.
Justin
Old May 18, 2011 | 09:22 AM
Zip Corvettes
The brackets for P/S and non P/S were different because the pulleys on the alt were different. The P/S big block car the alt was driven only by the PS where as a non PS car the alt was driven from the crank and waterpump pulley. So you really can't mix and match the setup, you have to go with one or the other depending on you application. If you need help please do not hesitate to call us.
Justin
Old May 18, 2011 | 09:59 AM
BBCorv70's Avatar
BBCorv70
The bracket for non power steering application is #3882810.
A photo here...
http://cgi.ebay.com/ebaymotors/1966-...45037824807052
Looks like it's available..
BTW: If you have an AIM, look at LS5 option pages. The non PS alternator installation is illustrated there.
Old May 18, 2011 | 10:34 AM
scottyp99's Avatar
scottyp99
Wow, big-block with no power steering, you must have pretty big arm muscles!!!
Scott
Old May 18, 2011 | 11:05 AM
DRIVESHAFT's Avatar
DRIVESHAFT
The Camaro bracket fits just fine........until you close the hood. Dont ask me how I know this.
Old May 18, 2011 | 11:06 AM
BBCorv70's Avatar
BBCorv70
Scott
Not necessarily. Mine didn't originally have power steering or power brakes. Steering wasn't hard if the car was moving. Parking was a bit of a pain. No power brakes was like trying to stop a train...
Old May 18, 2011 | 11:55 AM
scottyp99's Avatar
scottyp99
Ya know, now that I think of it, I have had cars with manual steering, and they weren't so bad, I think I am imagining a power steering car with the power steering conked out.....very hard to steer, if it's ever happened to you, you know what I'm talking about! Sorry to highjack the thread, just consider this a bump, and I will now go away, since I have nothing constructive to offer. See ya!
Scott
Old May 18, 2011 | 01:16 PM
Ironcross's Avatar
Ironcross
I have 3 of these, a 67 and 2 68`s.....all factory stock except for the transplants....and all use a cast iron bracket attached to the left head....as my yellow Vette does.....so whats different all the engines are the same size externally?
.I cant find a solo picture of the lower brackets but is in the Zip catalogue noted in an above thread
Old May 18, 2011 | 01:18 PM
DRIVESHAFT's Avatar
DRIVESHAFT
The non-Corvette bracket mounts the alternator higher.
Old May 18, 2011 | 02:24 PM
Ironcross's Avatar
Ironcross
Scott
thats what they say,.......
To 454 Alternator bracket
Old May 18, 2011 | 03:03 PM
Zip Corvettes
They look identical if you are looking at them on the engine. Yes the same bolt holes on the engine. The issue is the Camaro bracket puts the alternator in a different spot then it does on the Corvette.
Old May 18, 2011 | 06:18 PM
Ironcross's Avatar
Ironcross
OK, I`ll buy that .........thanks I think....
Old May 18, 2011 | 06:49 PM
Ironcross's Avatar
Ironcross
Scott
see, and just from steering a non PS Vette.....
