Header Wrapping
Old May 16, 2011 | 12:47 AM
jtramont's Avatar
jtramont
Default Header Wrapping
I'm looking for some opinions on this if anyone has any experience....
I just went through my first experience of wrapping my headers. Everything went fairly well however when I got done, I noticed that there is one spot where the header is exposed when you look down on the header from the top (area about the size of a quarter).
The "cause" is that at that location, the header tubes are too close together to get another wrap on the one pipe, and when I try to cover it when wrapping two tubes together, it leaves the area open from above. The only way to correct that I can determine is to over wrap the pipe which I've read is not a good idea due to hot spot creation.
Do you think that the space will defeat the purpose or cause any issues or would I be better off with the extra over wrapping? I'm thinking it should be ok but am clueless in this area.
Old May 16, 2011 | 02:19 AM
Clubby99's Avatar
Clubby99
Not a problem
Old May 16, 2011 | 08:59 AM
mikejpss's Avatar
mikejpss
From: Where it's always hot as Hell-South Louisiana.
St. Jude Donor '07-'08-'09-'10-'11-'12-'13
I have Hedman long tubes. The paperwork that cam ewith them said if you wrap the hedders, the warranty is void. Keep that in mind.
Knowing this, i wrapped mine anyway. I used 1 inch X 50 ft roll (on each side) and it was enough to wrap them down to the big 90 degree bend, then re-wrap them back up. That hole you described was covered on the re-wrap. My engine bay is much cooler, and so are the spark plug wires/looms.
Old May 16, 2011 | 04:25 PM
FKING1's Avatar
FKING1
If the headers are not stainless or coated, moisture can build up & rust them.
That is why some mfgrs will void the warranty.
Old May 16, 2011 | 06:20 PM
mikejpss's Avatar
mikejpss
Painted mine with the VHT rattle can paint. Am aware they will probly rust away anyhow, but at $240 delivered I can afford to change them out every 6-7 years. Or maybe my wife's next husband will have to deal with this issue, who tf knows?
Old May 18, 2011 | 06:02 PM
jtramont's Avatar
jtramont
Thanks guys, mine were not new but only had a couple of small rust spots which cleaned right up with a wire wheel. I do everything I can to avoid driving in the rain and it's pretty arid in Colorado so the rust factor is minimized. I did pretreat them with VHT and had to do something to protect the plugs and wires.
Old May 18, 2011 | 06:57 PM
vettehardt's Avatar
vettehardt
Also be aware that if oil gets soaked intot he wrap, it will cause a fire. I have seen about 4 cars catch fire because of this. Luckily all 4 were put out quickly with little or no damage except to the wrap.
Old May 18, 2011 | 07:26 PM
jtramont's Avatar
jtramont
Thanks I was aware of that. DEI makes a silicone based spray coating, something like paint, which will help prevent oil from soaking into the fabric. Nothing is 100% but supposedly it helps.
To Header Wrapping
