Interior Fan Runs
Old May 17, 2011 | 09:11 PM
Mark Hawkins's Avatar
Mark Hawkins
Default Interior Fan Runs
I have an 81. When I turn on the ignition, I hear a fan running. The controls are in the OFF position. Must be connected to a heater hose of such because it gets a little warm. How to start to trouble shoot this?
Old May 17, 2011 | 09:16 PM
...Roger...'s Avatar
...Roger...
Thats normal,its built that way.
Old May 17, 2011 | 09:45 PM
trainor's Avatar
trainor
In the summer if I'm not gonna run the AC i'll unplug it at the firewall and problem solved.
Old May 17, 2011 | 11:10 PM
SanDiegoPaul's Avatar
SanDiegoPaul
From: San Diego - Deep Within The State of CONFUSION!
do you have the manual? Look up Astro ventilation...
the car is designed to have the fan run all the time.
Old May 18, 2011 | 01:16 AM
HamadUP's Avatar
HamadUP
St. Jude Donor '08
Its strange that I don't have that feature in my original A/C '71 'vette, but I do have it in the '70 Z28 Camaro. I don't know how much amps does it consume, but is there anyway to disable that feature?
Old May 18, 2011 | 10:41 PM
Mark Hawkins
Thanks so much. I had a '72 from '78 to '85. I can't remember that one having the fan run on it. I will have to look up "Astro Ventilation".
Old May 18, 2011 | 11:29 PM
milo30's Avatar
milo30
My '78 does it also. Isn't it suppose to cycle in fresh air, they just didn't consider that it was HOT air.
Old May 19, 2011 | 12:33 AM
RJ80's Avatar
RJ80
If you want it off (when it is on the low setting), just disconnect the harness at the resistor (mounted on top of the heater/ac box under the hood), bend over the tab that is connected to the dark brown wire and then reconnect the harness. Low will be off and the other settings will function normally.
Old May 19, 2011 | 07:44 AM
bashcraft's Avatar
bashcraft
GM in their infinite wisdom decided that the air in the cabin could get "stale" on a long trip causing driver fatigue, so this was their solution. I believe all GM cars at one time had this feature.
At least that's what I've heard.
Old May 19, 2011 | 07:51 AM
...Roger...
Yes,that's what I understood the reason to be,keeps the heater box from smelling bad. However the air shouldn't be hot if the under hood coolant shutoff valve is working correctly. These systems worked very well off the showroom floor,many of these fixes (manual shutoffs)are IMO ,band-aid fixes.
Old May 19, 2011 | 08:23 AM
RonR80's Avatar
RonR80
St. Jude Donor '09
Mine is the same but if your feet are getting hot just move the lever to defrost and away the hot air goes, I did this for yrs. Ron
Old May 19, 2011 | 08:43 AM
dembo's Avatar
dembo
Unfortunalty not all years came with the coolant shutoff valve (see Paul's thread)
me Reminiscing times when the car actually drove & the temp at the feet was unbareable.
Old May 19, 2011 | 08:55 AM
...Roger...
Don't get me wrong,I'm not knocking guys for installing the manual shutoffs,only that its not needed on cars equipped with a factory one.
Old May 19, 2011 | 09:03 AM
bashcraft's Avatar
bashcraft
Well that makes sense.
Old May 19, 2011 | 11:16 AM
dembo's Avatar
dembo
It's not criticism Roger I just wish I had one lol as I don't like the looks of a ball valve in the engine compartment myself
Nick
Old May 19, 2011 | 01:56 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by SanDiegoPaul
...Look up Astro ventilation...
...I will have to look up "Astro Ventilation"...
No need to look. Astro-Ventilation went out in 76. It was GM's trade name for the fresh air ventilation system on the 68-75 cars.
Old May 19, 2011 | 02:01 PM
RonR80's Avatar
RonR80
St. Jude Donor '09
On my 80 I hid the ball valve shut off under the air cleaner intake hose on the passenger side , hard to see it.Ron
To Interior Fan Runs
Old May 19, 2011 | 02:43 PM
7t9l82's Avatar
7t9l82
may not be bad to have that fan run, we have a battery behind us in the passenger compartment. don't know if a battery puts out enough gas to matter but acid fumes can't be good to breathe.
Old May 19, 2011 | 03:17 PM
noonie's Avatar
noonie
Original batteries had vent tubes to the outside.
Same as some BMW, Mercedes etc and they are still available.
Old May 19, 2011 | 10:29 PM
Mark Hawkins
thanks guys for the imput.
