battery mistake!!
Old May 18, 2011 | 09:39 AM
manfroni's Avatar
manfroni
Default battery mistake!!
I over tightened my negative terminal on my battery. It seems to be stripped in the battery itself. Any ideas on a repair, the battery is new.
Old May 18, 2011 | 10:30 AM
litpy's Avatar
litpy
Try taking it back, try telling them it just would not tighten up. Got nothing to lose.
Old May 18, 2011 | 11:19 AM
c69vete's Avatar
c69vete
Finalist 2021 C3 of the Year - Modified
2017 C3 of Year Finalist
Cruise-In VIII Veteran
St. Jude Donor '07
Try a slightly longer bolt.
Old May 18, 2011 | 11:35 AM
spinadog's Avatar
spinadog
....and don't overtighten...
Old May 18, 2011 | 11:36 AM
scottyp99's Avatar
scottyp99
I've never tried it, but I have heard people say you can helicoil it.
Scott
Old May 18, 2011 | 01:01 PM
MIKE80's Avatar
MIKE80
If all else fails, larger self-tapping bolt.
Old May 18, 2011 | 01:18 PM
Paul L's Avatar
Paul L
Exactly what have you stripped? Are you saying the battery post is loose internal to the battery? And turns? Or are you speaking of the cable terminal?
Old May 18, 2011 | 02:00 PM
c69vete's Avatar
c69vete
St. Jude Donor '07
I was guessing he was refering to the later screw in side terminal battery.
Old May 18, 2011 | 02:39 PM
joewill's Avatar
joewill
that is soft lead easilly stripped..
try a heli-coil
Old May 18, 2011 | 03:16 PM
69Vett's Avatar
69Vett
Corvette of the Year Winner 2017
2016 C3 of Year Finalist
on side terminal batteries,
the screw in terminal is simply a nut imbedded into the Lead around it,
too long of a bolt, or too much torq. and you will push the nut right out of the battery,
No perment repair, try and return the battery.
To battery mistake!!
