light switch
Old May 19, 2011 | 07:26 PM
cshelldiver's Avatar
cshelldiver
Cruising
Default light switch
77 Corvette, given to me by original owner, my mom. I have LOTS of little things wrong that I am trying to fix. Here is one: I have a question regarding the light switch. My interior lights come on when the doors are open, but when I have the doors closed and turn the light switch to turn on my interior lights, they don't come on. Any ideas on what I need to do to get that to work?
Old May 19, 2011 | 07:29 PM
dar322's Avatar
dar322
St. Jude Donor '12-'13
could be you need a new switch.
Old May 19, 2011 | 08:57 PM
...Roger...'s Avatar
...Roger...
usually the switch is the culprit. BUT ....sometimes and I did say sometimes it can be what is pointed out in this thread.
http://forums.corvetteforum.com/c3-t...s-missing.html
cshelldiver,what your doing when you rotate the light switch **** is grounding the white wire that goes to the courtesy lights,this turns them on.
Old May 19, 2011 | 10:51 PM
cshelldiver
Cruising
Thank you for this info, we thought that could be the problem.
Old May 19, 2011 | 10:52 PM
cshelldiver
Cruising
I have printed out the picture and information in the link you sent. Will definitely check it out. Thanks so much.
To light switch
