Lug Nut Torque
Old May 20, 2011 | 12:56 PM
76yellow's Avatar
76yellow
Default Lug Nut Torque
What should I torque the lug nuts at on my 79 with aluminum wheels ?
Old May 20, 2011 | 01:16 PM
MelWff's Avatar
MelWff
90 ft lbs
Old May 20, 2011 | 02:50 PM
scottyp99's Avatar
scottyp99
Originally Posted by MelWff
90 ft lbs
I know that sounds like an awful lot, but it's true.
Scott
Old May 20, 2011 | 04:03 PM
76yellow's Avatar
76yellow
Thanks Guys....I would have thoght more !
Old May 21, 2011 | 08:34 AM
Yeller81USNRet's Avatar
Yeller81USNRet
Keep a eye on them lug nuts I just had a wheel come off on my 81 with aluminum wheels. You can bet I am going to keep a closer on them.
Laterz
Ken
Old Apr 24, 2012 | 08:47 PM
Clams Canino's Avatar
Clams Canino
What about steel wheels (Rally) with stock steel lug nuts?
That's 80 - right?
-W (search function got me here)
Old Apr 25, 2012 | 11:10 AM
gcusmano74's Avatar
gcusmano74
Just carefully watch those guys with the air wrenches. They can make over 200 ft lbs, easily. And that much torque may warp your rotors.
Old Apr 25, 2012 | 11:57 AM
jb78L-82's Avatar
jb78L-82
I torque the aluminum wheels on all my cars to 90-100 ft-lbs ( I use 100 ft lbs). Have for 30 years and never had a tire come loose or warp the rotors on the C3. Never let anyone attach lug nuts to any wheels with an air gun. Costco, for example, uses the air gun on very slow to attach all the lug nuts and then torques each lug nut individually with a torque wrench with the weight of the car on the wheels.
Old Apr 25, 2012 | 05:27 PM
hunt4cleanair's Avatar
hunt4cleanair
I do all my wheels (aluminum) at 80 lbs, have for years and never had a problem. It was suggested by a local shop that had worked on Corvettes for years. Drives me nuts when a shop cranks them suckers down to the 200 mentioned above.
Old Apr 25, 2012 | 07:10 PM
Paul L's Avatar
Paul L
Yes, I have done 80 ft-lbs for years with no problems. Going to 90 would not hurt but I am stuck on what works for me.
On my 2007 Impala with steel wheels the GM dealer did a real job on me when switching from my winter steel wheels to summer alloys. Much too much with the air gun. I had a couple of rusty nuts and wished to replace them afterward. I had an X wrench and could not get them off. Imagine having a flat on the road! I complained and they were re-installed with a torque wrench. You really have to watch these "fast" jobs. Same torque for a Cruze/Impala/4 x 4 Sierra.
Old Apr 25, 2012 | 07:35 PM
mds3013's Avatar
mds3013
80 ft. lbs. for me also. I keep in mind that I might have to change a flat using the stock lug wrench. mike...
To Lug Nut Torque
