74 Corvette Manual shifter question
Old May 20, 2011 | 12:58 PM
HT1663WB's Avatar
HT1663WB
Default 74 Corvette Manual shifter question
Can you just change the shifter or do you have to replace the complete assembly? If you can just change the shifter what is the procedure?
Thanks, Bill
Old May 20, 2011 | 01:13 PM
MelWff's Avatar
MelWff
why do you want to change the shifter?
Old May 20, 2011 | 01:28 PM
7t9l82's Avatar
7t9l82
the stick comes off the shifter assembly. no real benifit unless there is some cosmetic reason. change to a Hurst shifter for a good shifter
Old May 20, 2011 | 01:31 PM
hugie82's Avatar
hugie82
I don't think you can remove the shifter without taking the whole shifter and linkage out. I will tell you its complicated with the reverse light linkage added to the mix to get it all to work right after you take it apart
Old May 20, 2011 | 01:53 PM
HT1663WB's Avatar
HT1663WB
The reverse lock out is messed up. You really have to hit the shifter hard to get into reverse. I tried replacing the lock out bar and spring but the bar just falls all the way down and there is no tension.
To 74 Corvette Manual shifter question
