1972 Carb help Qjet
Old May 20, 2011 | 04:38 PM
gterhorst's Avatar
gterhorst
Default 1972 Carb help Qjet
Hi looking for some help with a Qjet stamped (7054918). It should be from a 72 350, however I'm not confident as I bought the car in pieces. I'm missing what I think is the choke pulloff rod, i have a picture just can't post it. I'd be happy to send it anyone.
I think I need R68 which is pictured in the link below.
http://www.carburetion.com/Quads/chokepull.asp
if anyone can provide a picture of their carb or a reference of a good Qjet shop/store I sure would appreciate it.
My personal email gterhorst@chatsworth.com
ps how/can I post a picture as an image (without a url for it)
Old May 20, 2011 | 11:25 PM
gbvette62's Avatar
gbvette62
7054918 is not a 72 Corvette carb, or any Corvette carb, as far as I can tell.
If it was for any 1972 model year GM car, the 4th digit would be a 2, not a 4. The 4 as the 4th digit, indicates that it's a 74 carb, but the number does not match any 74 Corvette carb, so it most be from some other 1974 GM car.
72 350 Q-Jet numbers are 7042203 & 7042903 with a 4 speed, and 7042202 or 7042902 with an automatic.
Old May 21, 2011 | 12:16 AM
Mashman's Avatar
Mashman
Posting a picture will probably help you get the best answer.
Got to Photobucket.com, and create a free account. You can then upload your pictures there. After uploading, look for the 'share' tab. Copy the 'IMG' code, it should copy it for you automatically if you click on it. Then go to your post, and paste the 'IMG' code into it.
Old May 21, 2011 | 07:13 AM
TeaEye's Avatar
TeaEye
Default 7054918
http://www.oreillyauto.com/site/c/de...2447&ppt=C0359
Found this on O'Reilly's Web Site.
The Tab lists the S/N you have and in the Compatibility Tab says 72, Corvette, V8 - 5.7L vin K 350ci.
Corvette Black Book and Catalog of Chevy V-8 Engine Casting Numbers 1955-1993 doesn't list that S/N.
Old May 21, 2011 | 09:32 PM
gterhorst's Avatar
gterhorst
Thanks for the info on the pics, Here is the link
It is a vin K so I guess that makes sense - on another web site (forgot which one) I found that SN was listed as a service part for corvette.
Anyway still need to find the correct choke pulloff rod
Old May 21, 2011 | 10:28 PM
scottyp99's Avatar
scottyp99
Would you humor me and double check that carb number? It doesn't seem to make any sense to me, you may have misread it. Then again, it might be some weird factory replacement carb, or some damn thing.
Scott
Old May 22, 2011 | 08:49 PM
gterhorst's Avatar
gterhorst
Scott,
sure no problem here are some photos - number is correct. baffles me as well. Just fired it up today, engine runs strong.
I'd be interested in what you find.
Old May 22, 2011 | 10:43 PM
Mashman's Avatar
Mashman
I don't think the carb # matters, it's not the original, and it's obvious that it's a divorced choke style q-jet.
That said, it appears that you are missing a number of parts. You are missing the secondary choke rod, and the secondary lockout, and the divorced choke coil.
My guess is that the previous owner replace the intake manifold, and the new one did not have a place to mount the divorced choke. So the previous owner removed the secondary lockout, and choke rod.
What kind of intake manifold do you have?
Old May 22, 2011 | 11:06 PM
Peterbuilt's Avatar
Peterbuilt
Default Missing Choke Rod
This is carb #7042211 which is for a 72 truck, will this help you to find the missing rod?
Old May 23, 2011 | 10:38 AM
gterhorst's Avatar
gterhorst
Petes thanks for the photo.
Mashman - its a Summit intake sum-226008. thanks for the information on missing parts.
I have the divorced coil/rod and in process of making a bracket to hold it, unless you know where I can buy one.
Still need help on finding the correct choke pull off rod.
In the above picture isnt that the secondary lockout (stamped with 42723)?
or below with my finger on it?
Old May 23, 2011 | 12:30 PM
Peterbuilt's Avatar
Peterbuilt
Look at B & C, that looks like the fast idle cam.
Old May 23, 2011 | 12:32 PM
Mashman's Avatar
Mashman
I believe that is the fast idle cam you are pointing at. It appears that the fast idle cam is on in your picture, in my picture below, the fast idle is off, and you can just see the top of it.
Here is a picture of my carb, it's a 7042202, and should be pretty much the same as yours.
Here are a couple of pictures of the secondary choke rod - there is no number stamped on it.
Old May 23, 2011 | 09:44 PM
gterhorst's Avatar
gterhorst
thanks a bunch, helps out.
Old May 25, 2011 | 05:07 PM
scottyp99's Avatar
scottyp99
So, did you ever figure out if that was the actual carb number? You may need it to get the right rebuilt kit, etc.
Scott
Old May 25, 2011 | 08:53 PM
gterhorst's Avatar
gterhorst
Well I know what it is stamped on it...7054918 - I confirmed that. it doesn't follow normal numbering, comes up in several locations as "service part". The engine fires, carb/fuel pump works well enough at idle, after a few more adjustments/connections and I'll test it on the street.
Old May 25, 2011 | 09:51 PM
scottyp99's Avatar
scottyp99
OK, I think I may have found it!! According to the list of carb numbers in Lars Grimsrud's "How to Tune a Q-Jet", carb #17054918 is a Chevy SR (service replacement??) for 1972 Corvettes, Novas, and Camaros with 402-454 engines. The number is 17054918, maybe the 1 didn't get stamped hard enough, or is unreadable for some other reason. (although, it could just be some weirdo carb, I guess.) Primary jets--77, primary rods--48, power piston spring--7036019, secondary rods--CM. If I could see a picture of it, I could tell if it's a 70 or a 170, but I can't view pics on this computer, I'm at work, (he he, goofing off behind the boss's back!!)
Scott
Scott
Old May 26, 2011 | 12:16 AM
gterhorst's Avatar
gterhorst
Scott,
I put more photos at:
http://s1103.photobucket.com/albums/g465/gterhorst/
I think I see your boss coming - alt & tab.
Old May 26, 2011 | 12:38 AM
Corvette Kiwi's Avatar
Corvette Kiwi
Go with Sean Murphy Induction. He has done numerous Q-Jets for me and his work is outstanding.
www.smicarburetor.com
To 1972 Carb help Qjet
