Bonding on flares
Old May 20, 2011 | 10:10 PM
Blain's Avatar
Blain
Default Bonding on flares
Looking for pictures and suggestions on how to bond these flares.
I will use the upper bonding strip for the top but not sure where to go with the front and rear. Not one to re-invent the wheel so I thought someone out there would share their "wheel" with me
I did a full rear clip so this wasn't an issue.
Blain
Old May 20, 2011 | 10:54 PM
themetalman03886's Avatar
themetalman03886
I would just glass it in, do about 6 to 9 layers. Sand primer sand paint
Old May 20, 2011 | 11:14 PM
Blain's Avatar
Blain
Are you suggesting gluing it on the surface and feathering the edge?
Blain
Old May 20, 2011 | 11:26 PM
themetalman03886
Whenever I have laid glass I didn't glue the parts together first. I just mixed the resin as recommended and used that to bond the two pieces together. Just make sure the pieces are clamped together real tight and the fiberglass is fully cured. It's ok to go a few inches over on each side with the fiberglass. Just sand where needed to get the smoothest look possible
Old May 20, 2011 | 11:32 PM
SmokedTires's Avatar
SmokedTires
Cruise-In III Veteran
St. Jude Donor '05
Here are some pics from the late RollingThunder's flair install. He used some of the old fender for bonding strips and then screwed/clamped the flairs inplace while the glue set, removing the screws afterwards.
Old May 20, 2011 | 11:41 PM
Blain's Avatar
Blain
I think there is a difference between the flares that end at the base of the radius vs. the full panel like I'm doing. If I just glass them on the surface the whole body line gets lost.
Thanks for the pictures, worth 1000 words.
Blain
Old May 21, 2011 | 06:25 AM
dgood's Avatar
dgood
http://forums.corvetteforum.com/c3-g...storation.html
read this thread. it is only 94 pages long but stinger is doing everything on his body correctly and perfectly. the guy is amazing. pictures and all. it is over in the general section
Old May 21, 2011 | 08:37 AM
69 Chevy's Avatar
69 Chevy
To install the Eckler's ZL-1 flares, I used FUSOR #127EZ plastic structural installation adhesive, slow set formula. [I also used it to attach the cold air box to the underside of the heavy duty hood] I used TEK screws to fasten them in place, lining up the body lines. Then I trimmed the excess from both the flares and the original wheel wells. No cracks or delamination so far. Pennsylvania's roads are legendary for being the worst in the nation. And my F-41 suspension rides like the proverbial stonepile.
Old May 21, 2011 | 11:13 AM
Blain's Avatar
Blain
69 Chev, I'm doing the same ZL flares only I got them from Vanacors.
Did yours come with the extra material? I assumed since the flare lined up with the fender/hood surround bonding line that was where it should start.
Blain
Old May 21, 2011 | 09:14 PM
Mod75's Avatar
Mod75
2024 C3 of the Year Winner - Modified
Hope these pics will help. Used rivets to hold in place, tapered the flare and body before attaching.
Old May 21, 2011 | 10:53 PM
Blain's Avatar
Blain
Mod75, thats what I was looking for!
Have any pictures of the front where the flare blends into the chin? The Vanacor flares require some finish work.
Dove into it today. Used bonding strip at the rear
Blain
Old May 22, 2011 | 01:25 AM
eagle275's Avatar
eagle275
nice! looking forward to more pics.
Old May 22, 2011 | 01:37 AM
vetteguy22's Avatar
vetteguy22
Looks like quit a project. Good luck and keep the pictures coming.http://images.ibsrv.net/ibsrv/res/sr...lies/lurk5.gif
Old May 22, 2011 | 10:44 AM
Roco71's Avatar
Roco71
Nice work
Old May 22, 2011 | 12:55 PM
69 Chevy's Avatar
69 Chevy
Yes. But I did not cut away my OEM fender all the way to the bonding strip. I trimmed away lots of the, what I thought, was extra material. I taper-ground the area and overlapped. I did not want any butt joints where potential cracks could start. And yes, the front of the flare, where it joins to the spoiler chin did not match perfectly...it needed a bit of fabricating to get it to blend into the contour. Sorry no pics of that area.
Roco 71, you cannot imagine how many hours I spent block sanding those compound curves good enough for the black paint job. And it's only temporary. One of these days, months, years, it's going back to its original Monaco Orange color.
Old May 23, 2011 | 12:19 AM
Blain's Avatar
Blain
Productive weekend. 2 cartridges of 3M Duramix. That puts the total used on the car so far at around 10.
Mod75; What did you do for a front spoiler? If I blend the ZL flares to the lower fender the poly spoiler won't work.
Blain
Old May 23, 2011 | 09:47 AM
PatsLs1vette's Avatar
PatsLs1vette
Looking reAlly good, i did mine like rolling thunder did and used fusor.
To Bonding on flares
Old May 23, 2011 | 10:26 PM
Mod75's Avatar
Mod75
Blain, My flares from are from Eckers, about 30 years ago this was done.
How we are striping it for a new color.
The stock spoiler fit ok i think, i might of had to trim the ends.
Had to do very little work under the chins if i remember correctly.
Just put the spoiler and valence back on to drive the car, the spoiler does help with the air flow. Hope this helps
Sure wish my Eckler front bumper fit as good as yours, spending more time on the bumper than i did to strip the body.
Old May 24, 2011 | 12:17 AM
Blain's Avatar
Blain
I really had to fight the front bumper. Even questioned Vanacors about the fit. I "releaved" some of the grill area to get the part to flex far enough to mate with the front clip.
So looking at your front spoiler it appears flat across the top. My '74 curls up at the ends to meet the contour of the fender. Did you cut that part off?
Ahhh, progress!!
Blain
Old May 24, 2011 | 12:25 AM
Blain's Avatar
Blain
Mod75 check out page 3. Better bumper pictures of my last project.
http://stingray.blainstumpf.com/Gall...llery=461031#1
Blain
